Question about Epson Stylus CX6600 All-In-One InkJet Printer
Error message i have printer epson stylus cx6600 when i started itis appeared error message " printer error see your documentation and call service
  • JOSEPH5 Dec 06, 2007
    MY Epson Stylus CX6600 All-In-One InkJet Printer HAS NEVER LET ME DOWN. BUT NOW SCANNER WILL NOT WORK. I HAVE REINSTALLED BUT STILL WILL NOT WORK. ALL OTHER FEATURES WORK.
  • Anonymous Dec 07, 2007
    When I turn the printer on it says Error-Printer error See your documentation and call service
  • 4 Answers
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Posted on Dec 10, 2007
  • Leinster Lad Jan 27, 2011
    I tried this solution and it worked for me. Pity this solution isn't in the Epson troubeshooting guide.
    Good work Mr Dave - I think you should be promoted to the board of Epson and sort them out!
Mrdave get a life
Get error message "Printer error: see your documentation and call service if necessary."
I found this on another website and it worked for me. It apparently resets the printer. Hope it works for you:
1.) power on (error message)
2.) press the "Stop (triangle)" and the "Colour copy" button and hold them
3.) press the power button to power off, still hold 2.)
4.) press the power button to power on, still holding 2.)
5.) the LEDs start to flash, then they stop to flash and the red exclamation mark starts to flash. Now release 2.)
6.) the LED should say: "Init EEprom"
7.) now press and hold the power button until the printer powers off and powers on again.
May 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I want to scan a document to my computer
have you installed all the scanning software that came with the scanner, Install them and go through these steps to scan a document using Twain;
Overview of the Basic Procedure
This section outlines the basic scanning procedure using a TWAIN-compliant application. For detailed procedure, see the Scanning an Image.
Make sure the CX6600's power cord is plugged in.
Place your materials on the document table.
Start a TWAIN-compliant application.
In the application, open EPSON Scan.
Full Auto Mode:
EPSON Scan automatically previews the images and recognizes the document source and type. images are automatically optimized and scanned.
Home Mode or Professional Mode:
Make settings to optimize images and click Scan.
The scanned images are sent to the application.
Save the scanned images in the application.
Scanning / How to Scan
Scanning an Image
Turning on the CX6600
Placing your materials on the document table
Starting the software and scanning an image
EPSON Scan provides three modes for you to make any scanning settings; Full Auto Mode, Home Mode, and Professional Mode. This section describes how to scan an image in the Full Auto Mode. The Full Auto Mode lets you scan images using automatically-adjusted settings. For more details, see Choosing a Scanning Mode.
Note:
You cannot scan an image with a size that exceeds the available memory or disk space. If you try to scan the image, an alert appears on the screen.
Note for Macintosh users:
Most illustrations shown in this section are for Windows, so they may vary in appearance from what actually appears on your screen. The instructions are the same, except as noted.
Caution:
Before starting the following steps, make sure that all the necessary software including EPSON Scan has been installed. For details about how to install the software, see the Start Here sheet.
Before turning on the CX6600, make sure it is connected to your computer.
Press the On button to turn on the CX6600. All mode lights flash, then the mode button for the mode you used last lights, meaning it has completed its initialization.
You can scan reflective documents (like photos or paper). See Placing Photos and Documents on the Document Table.
You can start EPSON Scan in the following ways.
* Start EPSON Scan directly as a stand alone application
* Start EPSON Scan from a TWAIN-compliant application
This section provides information on how to start EPSON Scan from ArcSoft PhotoImpression. For details on starting EPSON Scan as a stand-alone application, see Starting EPSON Scan.
Note; if you are using Windows 98:
ArcSoft PhotoImpression 5 supports Windows 98 Second Edition or later. For version earlier than Windows 98 Second Edition, use EPSON Scan or other TWAIN compliant applications. See Starting EPSON Scan for details.
Start ArcSoft PhotoImpression.
For Windows users:
Click Start, point to All Programs (for Windows XP users) or Programs (for Windows 98, Me, or 2000 users), and select ArcSoft PhotoImpression 5. Click PhotoImpression 5.
For Macintosh users:
Double-click the Applications folder on your Macintosh HD, then double-click the PhotoImpression folder. Finally, double-click the PhotoImpression 5 icon.
Click the Camera/Scanner button.
Select a file format, location, and file name, then click Epson Stylus CX6600. EPSON Scan starts. See File formats for information on file formats.
Note for Windows XP users:
Do not choose WIA-Epson Stylus CX6600 from the menu to select the CX6600. If you select it, you cannot use the Epson scanner function fully.
EPSON Scan automatically previews the image, and recognizes the document source and type.
If you want to select more settings, click Pause, then click Options to open the Options dialog box. For more details on settings, click the Help button in the Option dialog box.
After EPSON Scan has previewed and recognized the document type, the following window appears. You can see the document type in the window.
EPSON Scan automatically locates the target images, modifies their skew, and starts scanning.
Caution:
Do not open the scanner unit during scanning or copying; otherwise, you may damage the CX6600.
Note:
Be aware that clicking Cancel on this screen closes EPSON Scan.
The scanned image is sent to ArcSoft PhotoImpression.
Note:
* Depending on the image you want to scan, you may not get the expected scanned image. In this case, scan the image in the Home Mode or Professional Mode.
* When you scan in the Full Auto Mode, black and white documents might be recognized as a color document. In this case, scan the image in the Home Mode or Professional Mode.
If you still experience problem scanning, un-install the entire software and re-install them all over. Install all the packages in the CD. Cheers!
May 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer error
follow the link for downloads, faqs,troubleshooting, documents and manuals.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=41664
Mark
Apr 10, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Service required error
Ok.. aside from the fact that you've posted under the R300 Epson model thread you're still in luck.
The CX6600 has been documented (by me admittedly) with a complete guide to fitting an external tank and resetting the waste ink counter in the printer.
http://www.octoink.co.uk/store/pages/Epson-CX6600.html
Just to note: This is a commercial site but the information provided is generic and will help you fix the problem.
Feb 15, 2009 | Epson Stylus Photo R300 InkJet Printer
Red light
Your printer appears to have hit he "ink overflow protection counter" meaning that it thinks the waste ink pads in the base are full.
If the printer is in warranty, get Epson out to it. If not you can sort the error yourself using the rescue kit for the CX6600 available here: http://www.tradebit.com/filedetail.php/2379162-stylus-cx6600-rescue-kit-zip
Oct 13, 2008 | Epson Stylus CX6600 All-In-One InkJet...
My Epson Styluss CX6600 won't charge
This may be very simple. Turn the unit off and lift up the top. On the forward side of the unit you will find a little 'slider switch'. This is the scanner unlock - toggle the switch back and forth several times and leave in the unlock position. Turn on the printer and all will be well.
Aug 26, 2007 | Epson Stylus CX6600 All-In-One InkJet...
EPSON STYLUS CX6600 - PRINTER ERROR SEE YOUR DOCUMENTATION AND CALL SERVICES
Could be the waste ink tank is full. Take a look in at www.fixyourownprinter.com. Aslso a useful download is the SSC Epson utility that carries out many 'managment' functioms and has its own forum also www.ssclg.com And last but not least - Epson customer support
Aug 06, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
420 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
