I don't know what was done to open it but possibly, the latch got bent, either in the door or on the front of the unit, where it latches. BOTH latching pieces must be 90° from the unit. If they are more, it won't latch. If they are less, it won't pull tight. If either got bent in too far, they will miss, when you try to latch the door.
A pair of offset pliers, like channel locks work well to realign them.
If you used force to push it shut when it was stuck open, then you may have bent a hinge. Another possibility is that something fell into the hinge mechanism on one side and is jamming it.
On the other hand, if it was stuck shut, you could have a problem with the door latch.
SOURCE: leaking problem from the door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
SOURCE: samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Testimonial: "thanks, ill try that now"
SOURCE: detergent door won't close, dishwasher won't start
Contact a professional technician to see if the spray loaded action needs to be replaced with a new cup area.
