Question about JVC TH-S3 System
Loading tray permanently in locked state
The DVD was bought in Geneva but unfortunately with a wrong remote control unit and a user's manual tha isnot in English. How can I unlock it to enable it to eject?
  • Stanislas Chimgoga Dec 07, 2007
    I got this from a JVC manual but of a different Model
  • Stanislas Chimgoga Mar 13, 2008
    I found the solution from a jvc manual of different model. Apparently they have the same features.
    Thanks.
    ampere.
Turn the Player to stand by and press Pause and Eject at the same time this switches on the dvd and unlocks the tray
Posted on Feb 26, 2008
  • Haha450 Dec 05, 2010
    This works! Thank you, I was starting to go mad!
  • kelly_collig Dec 12, 2010
    thank you thank you thank you whoever posted this!! the on line manual i looked at was wrong so i followed this advice and whey hey my tray opened!!!!!!!!!!!!!!!!!!!!!!!
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
DVD will not load or play. Just keeps saying loading over and over
This probably means that your DVD player has a dirty lens or a tracking problem or both. If the DVD player has a tray, you can try putting an optical disc lens cleaner into the unit. (Slot-loading DVD units may not properly accept or eject the disc. So don't try a cleaning disc in that type of unit.)
Since most DVD players are cheap, it's usually better to replace the unit if the tracking is bad. Similarly, if a lens cleaner does not work, replace the unit. If the player is under warranty, contact the manufacturer.
I hope this helps.
Sep 29, 2013 | Toshiba Se-r0047 Remote Control
How do you unlock child lock on a LG BH100 Blu-Ray Disc Player?
Sorry, to say that the user manual states that the only way to turn on/off the child lock is to use the remote control.
The manual can be accessed using this link and following the on-screen instructions:
http://www.retrevo.com/support/LG-BH100-DVD-Players-manual/id/1074bh627/t/2/
Time to check under the cushions for the remote controller!
Peter
Mar 08, 2012 | LG BH100 Blu-Ray Disc Player
LG DRT389H will switch on OK but will not allow Disc draw to open, & will not react to ''menu list'' or any buttons on the remote OR on the front of the machine. When switched on, shows...
Hello!
There is really no better way than to remove the case cover and access the mechanical loading disc tray of your unit,
You will need to remove all screws to remove the case cover. Inspect the mechanical loading disc tray. There is usually a left disc not properly placed in the loading tray that causing the jam.
Check also if there is no broken teeth on the gear that drives the movement of the tray. You can lubricate it with oil or greese to help it move freely.
Sep 04, 2011 | Televison & Video
Can't open loading tray on Yamaha RDX-E700
Is there a pinhole in the face of the DVD player near the drawer?
Apr 01, 2009 | Audio Players & Recorders
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
Unlock my dvd player
try this
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
I bought mine tonight. The above procedure works perfectly. It is now set to 0, and I confirmed via firmware version page.
Cheers!
Sep 06, 2008 | Philips Magnavox DVD/VCR Dual Player
Region Settings
Turn Player On
Open The Disk Tray (Leave Open)
On Remote Control Press Stop
On Remote Control Press 1.3.6.9 and 0 (Zero)
Close Disk Tray
Power Off
or
Turn Player On
On Remote Control Press Clear
Close Disk Tray
Power Off
Jun 28, 2008 | Disney DTD1363-CAR 13" TV/DVD
Un-lock dvd region code
Power up the unit with no cd/dvd on the tray
Press "eject" on your remote to eject the tray
Press "setup" on your remote
Key in "5018" using your remote
Key in "0"
Press "play" on your remote
Tada~ a region free dvd recorder
Tried this but unfortunately the machine keeps reverting back to Region 4.
Has a step been left out or is there some other way of changing the code to "0".
Jun 14, 2008 | Televison & Video
DVD will not eject
The disk cannot be taken out by setting the Tray Lock, please follow the steps below.
Turn Unit ON.
Set the DVD to the Stop Mode.
Press and hold the ‘STOP’ key on the front panel.
Simultaneously press and hold the ‘9’ key on the remote control unit.
Hold both keys for more than 2 seconds.
Press the OPEN/CLOSE key on the front panel to check the Tray Lock setting.
To unlock the Tray Lock, please follow the steps below.
Turn Unit ON.
The Tray Lock has now been cleared.
Nov 09, 2007 | Toshiba 20HLV15 TV
JVC TH-S3 System Logo
212 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
