PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Ibook
By darren4 on Dec 05, 2007
hi my girfriend lap top is an ibook the screen is not working can you help the store wants alot of money to fix it she is a student so money is a proplem everything else works fine.
thanks.
Solution #1
posted on Dec 05, 2007
Somewhat Helpful)
bsrjth
Rank: Wiz
Rating: 82%, 353 votes
may be damge in connector cable (moost probable chnce as it moving throuth hinge
Was this helpful?
Yes
No
Solution #2
posted on Aug 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
connect the laptop to an external monitor via it monitor out plug ,
Solution #3
posted on Jan 09, 2008
Not Rated)
Rah-digga
Rank: Apprentice
Rating: 0%, 0 votes
I have the same thing happen to my iBook. If it's the older G3 version it's most likely the video card. This is a fairly common problem I found while researching on the net. The ibook's video card runs hot and the soldering between the mother board and the chip have become loose. Do you still hear the fan come on? Do the lights for the Caps Lock and Number Lock keys still come on when you press the buttons? When you connect to the VGA adaptor and try to hook up to a regular monitor does it still come up blank? Then yes it's the chip. Buying a replacement screen won't fix it. My fix was sort of a bootleg; basically take the bottom panel off, remove the silver heat shield and you'll see the chip covered in the thermal pad. Scrape the padding off, get yourself a good heat sink and cut the legs off. Make sure not to cut it flush or just by smaller mini heat sinks. Put thermal paste on the chip, put the new heat sink on, put the heat shield back in place, put the bottom back on. One thing to note is that the new heat sink you put on needs to be big enough so that the bottom cover and heat shield DON'T fit comfortably; needs to bubble out a little so that the chip is under tight pressure and presses firmly in place on the mother board. Like I said it's a bootleg but my ibook works fine.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
i cant find the webcam on my laptop acer aspire 5532
Answer
pages skip & don't display fully
Answer
where is the wireless switch on the compaq presario laptop
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
