Thomson 32VT63J0 setting up problem
I have today been given this TV with remote. Have plugged my cable box and leads in and switched on to find snow. I am not in the least bit technical when it comes to televisions etc. and unfortunately the manual was not included. I presume I have to programme the television in again but don't know where to start. Can I get a copy of the manual on the internet or could you help me please.
    Genius:
  • 1,694 Answers
After basic cable box hook-up with coaxial to TV, the next step
is to select channel 3 or 4 on the TV because most source boxes send out their signal to one of those channels.
An alternate hook-up is to plug-in yellow,red and white from the
cable box to the same colors on the TV, then select video input
on TV...................Let me know if you need more info......T
Posted on Dec 05, 2007
Kod na univerzalny ovladac RM 88E na TV THOMSON
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily...
http://electro-medical.blogspot.com/
Mar 17, 2016 | Thomson Televison & Video
I have a Thomson digital tv recorder 500g dt1602tut i need to know if there is a auto scan for the tv codes on the remote as i have a venturer tv and cant find the code please help
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 30, 2015 | Thomson Televison & Video
Thomson roc 6407
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
Jul 12, 2014 | Thomson Televison & Video
Green light stays on when trying to turn off tv. picture go's off when cable remote is used but green light stays onand you can see that screen is still on?
You need to set up the cable box remote for your TV , now you are just turning off the cable box. Some cable boxes have a switched plug on the back that will turn on and off with the box. If yours has the switched receptacle you can use that to turn the TV on and off by plugging your TV into the switched receptacle. Make sure the TV power is on, the receptacle will kill the power so the clock on the TV wont work. Otherwise you need to set the code for your TVs remote and use the system power button.
Apr 23, 2014 | Mitsubishi LT-46153 LCD TV
Innovage jumbo remote controls channels on cable box but nothing on tv
You should set the remote control with your TV too, with the setup code to your TV brand. Find it from the remote control's code list, and set it up with. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 10, 2013 | Innovage Jumbo Remote Control
Lost my TV remote but have a diferent thomson remote .Should the secondone work on my tv
You can find inexpensive universal remotes that work with Thomson here: http://www.electronix.com/remote-controls-c-9.html
May 25, 2011 | Thomson Televison & Video
How do I retune my Thomson Digital TV 24WK25UG after digital switchover in Granada area
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
Dec 04, 2009 | Thomson 24WK25U 24" TV
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
Blue screen
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
Aug 18, 2009 | Sansui DTV2760 27" TV
No remote; cannot receive cable
get a universal remote it should work
Oct 31, 2007 | Samsung TXH1970 TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
