Question about Philips 19PR19 19" TV
Bright line coming in center of screen
Suddenly bright silver line coming in center of screen
Hi Shailendrar , your problem sounds like vertical collapse , the whole picture has collapsed into a thin , very bright centre line ? maybe the result of dry solder joints , does banging on the side of the tv temporarily fix ? if so , the circuit board requires inspection for bad solder joints . Alternately the vertical chip/transistor may be blown , replace as required. Cheers T
Posted on Dec 05, 2007
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
Samsung intensity lines on screen
Try to change brightness
Feb 25, 2014 | Cell Phones
Horizental line center of the screen
Horizontal thin bright line across the screen, denotes the vertical sweep failure. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | Vizio Televison & Video
Witch port do you use to charge the system the system is low on ref.
There should be a bright silver canister under the hood. Coming out of that should be a silver line. Along this line, there is a plastic cap you can unscrew to reveal the port that a charging kit can connect to.
Feb 28, 2011 | 1999 Chevrolet Silverado 1500
Black screen with bright horizontal line through center
Your vertical IC may need resolder. You may have a bad capacitor or two that created an extra warm IC and create bad grounds. So resolder and check those caps near and around your vertical IC. If you continue to see this horizontal line you may have to replace the vertical IC. And you may as well check all grounds as well. Good Luck and be careful!
Jun 18, 2010 | Broksonic TV
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
My videocon 29'' showing a bright horizontal line in center of screen after 2-3 min of start up, & full picture will not come
this we call vertical problem need to resolder vertical ic or to check on vertical side is there 24vdc supply is coming to ic
Jun 07, 2009 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Philips 19PR19 19" TV Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
