Question about Toshiba PDR-M81 Digital Camera
Date and time stamp on the pictures
I would like for the date to show on the pictures after i have put them on my computer, but i can't figure it out. help!!!!!!!!!!!!
0 characters
1 Points
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
Mar 01, 2013 | Panasonic Digital Cameras
I need to figure out how to put a timestamp!
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jun 15, 2010 | Fuji FinePix J10 Digital Camera
How to show time and date stamp on my photos using
May not be a way to do it. Personally, I think it is a poor thing to do. When you put the time & date on a picture this way, it cannot be easily removed. Since the EXIF data has this and much more information, you can always add it later.
Nov 19, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
How to activate time and date stamp on the pictures taken with olympus x-840
Well, not really a solution. More like clarification.
Olympus does not provide a date/time stamp on pics taken with this camera (f310/x840), so, no solution, just knowledge....
Jul 06, 2008 | Olympus FE-210 Digital Camera
Need help
go to function and change pic size to wide or it shows a w -then you will see in main menu highlight of time and date stamp-canon can only do date and/or time in a certain size pic-rember it's a lower quality resolution than normal-change pic size first at bottom of function menu then go to main menu
Jun 09, 2008 | Canon PowerShot A560 Digital Camera
Time/date stamp on pictures when printing
I had the same problem. I wanted to set my Olympus C5000 Zoom to automatically date stamp photos. After going through the entire manual, I had to call Olympus directly. They told me that none of their cameras have an internal date stamp feature. They said that the date stamp lowers the quality of the picture, so they choose not to have the feature available. However, you can manually add the date and time stamp through the software that comes with the camera, just before you print the pictures. Hope that helps...
Apr 14, 2008 | Olympus Camedia C-5000 Zoom Digital Camera
Date/Time stamp
the date and time stamp will only show when the picture is printed from the memory card.
Apr 08, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Display date & time on developed pictures
When you say it's displayed on the screen, do you mean while it's in playback mode, it's embedded there?
If not, you will have to put your resoltion in postcard mode and make sure in menu that your date or date/time stamp is turned on.
To get to your resolution settings, turn camera on to shooting mode, hit function/set button and arrow down to the bottom left corner where it will show your resolution (L,M,S, etc) and this is where you will find postcard mode.
This setting is the only one you can use date time stamp and will show up in prints, but only good for 4 x 6 prints, anything larger will not be good resolution, it will be pixelated because it's only enough quality for a small print.
Hope this helps!
Mar 12, 2008 | Canon PowerShot A460 Digital Camera
Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know
Feb 02, 2008 | Olympus Camedia C-60 Zoom Digital Camera
Date and timestamps
Is there a way to select a group of pictures on the camera and give them all the same date and/or time stamp?
Each JPG will show the date on which it was taken, but not on the photo, it will show it on your computer under the column "date picture taken"
Jan 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Toshiba PDR-M81 Digital Camera Logo
55 people viewed this question
Top Toshiba Digital Cameras Experts
john milligan
isaac johny
isaac johny
Are you a Toshiba Digital Camera Expert? Answer questions, earn points and help others
