Question about Brother IntelliFax-2820 Laser Fax
Set up I am just setting up my new brother 2820 fax machine. I realised that I will need to add distinctive ring for my fax machine to pick up, but can I still have voice mail on the other line? thx. Also will I still have caller ID?
    Novelist:
  • 208 Answers
Make sure ECM is turned on. Do not turn on Junk Fax because you will most likely block other faxes.
If you really want the fax machine to work properly, you should connect it to a dedicated line.
You will be disappointed with performance if you try sharing it with other items on the same line.
Reasons, your fax line will be busy when your other functions are being used, and obviously you will miss faxes.
If you are taking a call or message when fax comes in, if the machine is made to give faxes first priority, you will be disconnetcted.
Also, which one do you want to set to pick up first?
The fax machine answers on a certain ammount of rings and so does Voice mail. Which has priority to you. DO you want to miss faxes for messages, or messages for faxes.
Set up vioce mail for 3 rings and fax for 4, then you miss the fax. Reverse it and you miss the message.
Just telling you, I have people call all the time for issues with faxes on the same lines with other items, Answering machines, credit card billers, other phones, etc etc etc.
Good luck. But putting multiple items on the same phone line is setting you up for disappointing performance. And it will not be the problem of the fax machine, It is designed to do what it is supposed to.
Just telling you the truth up front. If your faxes and messages are both important to you. You need a dedicated line for the fax.
Posted on Dec 05, 2007
How do you set the number of rings before thepick up?
I don't know for that particular model, but it should be in the manual somewhere. If not, what I like to do is just play around with the settings until I find the right one. If the fax machine has a screen on it, that should be much easier.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Auto answer
first print out a help list this will tell you how to set the rings for the fax machine. it can be set up to ring on the six ring. try going into the receive menu and follow the prompts. good luck
Dec 25, 2008 | Brother IntelliFax-2820 Laser Fax
My fax machine answers my phone calls
you have a crossed phone line in the wirering coming out of the phone jack at the wall
Dec 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
It just ring, ring, ring, but no fax come thru
DR = Destintive ring
This mode is set to on, you need it off, it's in the menu settings somewhere have a hunt or goto brother webite and get manual.
Oct 19, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
127 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
