I inherited this nice monitor but it will not power up!
I am sure it has the correct power going in but get
no lights or sounds at all.
Can use the same power cord to a diiferent monitor and
it comes right up, so the power in is ok.
I am using the RGB connector but it doesn't even get power
to the unit at all it seems.
Is there a fuse or capacitor that might need replacing?
Does anyone have a similar problem?
This monitor was sitting for a few months but was supposedly
working ok before it was stored.
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an...
(More)
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an the mossfets show signs of overheating, but they are pretty rugged (will replace anyway). I foind a componant that seems to have overheated and shorted it's at location RT100 just behind the main power connector and fuse F101. What is it? If it is a resistor what is the resistance it should be at? (exterior discolored) Where can I get a wiring diagram? (to findout if you guys don't know)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a...
(More)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a few moments the menu pops back up and wont go away, ive rebooted unpluged everthing mIcan think off it wont stop coming back up and peventing me from seeing whats on the other side I havea hp w1907 widescreen
I just noticed today that there are faded dark patches after all the text and images on my screen....
(More)
I just noticed today that there are faded dark patches after all the text and images on my screen. Is my monitor just bad or is there a setting to fix this?
