Question about ASUS (ASUDVDRWM6N) DVD-RW Burner
Asus drw-1814blt pc crashs as soon as disc is placed in drive
  • welamb Dec 21, 2007
    it posts a comment that there is problem with the driver.
  • 417 Answers
Hi there reinstall the driver is you have the disk if not download from drivers.com there will be a small charge for download if not go onto your PC manufactures website and see if you can download from there.
Thanks J
Posted on Feb 06, 2008
How to install a ASUS burner
In a PC, simply open a drive space on the computer, insert the drive by sliding it into the slot and screw it in place. On the rear of the burner are two connections. One is for the Power attachment and the smaller one is attached to motherboard.
That's it.
Oct 29, 2013 | OEM Systems Asus Drw-24b1st Dvd / Cd...
My ASUS DRW 1814 BLT does not recognize the Lightscrib discs. I have windows 7 32 bits
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 14, 2011 | ASUS DRW-1814BLT DVD±RW Dual Layer Burner
DRW-1608P 3S - doesn't show on 'my PC'. On 'device manager' there's the name but with an exclamation mark over a yellow circle. My daughter was deleting old programs before, to make room for photoshop....
you need the drivers for this hardware (DVD Drive) also sometimes a firmware update is necessary in order for it work properly
asus-drw-1608p3s-u-1-24-firmware-vt1486.html">http://www.inetbridge.net/forum/driver-asus-drw-1608p3s-u-1-24-firmware-vt1486.html
this is direct link http://www.inetbridge.net/forum/download/file.php?id=1622&sid=db1912e34e9b2e8bf95cd864a78f2d2b for the drivers / firmware download
download the file, extract the content and it will do the rest. make sure to have your dvd drive connected to your computer.
Mar 09, 2011 | ASUS (GENEIRC DRW-1608P BLACK)...
ASUS DRW 1608 P3S will not load CD Rom computer program disks (it makes clicking sounds then green light goes off and nothing happens). It will play movies but there is no audio, however it will play CD's...
the lazer is not reading try cleaning it with a lazer disc cleaner. but remember most pc burners need replacing after just 2 yrs of work as there lazers burn out fast
hope this helps
Dec 28, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Oct 22, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
ASUS DRW-2014l1t DVD burning problems.
Hi, try to buy optic lense cleaner of dvd.
Try also nero if also available.
Jan 19, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Wont work
Sounds like there may be an issue with the drive itself. I would return it or replace it. As for windows...If this problem persists after a replacement, i would re install windows.
Dec 27, 2006 | ASUS DVD_BURN |DRW-1608P3S BK W/SW R...
ASUS (ASUDVDRWM6N) DVD-RW Burner Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
