Question about ASUS P5S800-VM Motherboard
RAM Speed Hi,I have problem in RAM speed. I have put 512MB of 333MHz speed RAM. But system speed is too low. Before this i had 256MB RAM. Compare to 256MB, 512MB must be very speed. But i can't get speed. Please give me solution for this.
  • Anonymous Mar 27, 2014
    512mb already installed
  • 661 Answers
There are many things that govern a computer's speed,
1 The speed of the Hardware IE the Processor, Memory and Graphics Card all contribute to this, (It is assumed that this is working well in whatever configuration you have)
2 The Requirements of your software....Win XP SP2 REQUIRES a minimum of 512 Mb Mem to run properly (if it has less than this it will run very slowly even with only basic Applications installed IE Norton/Mcafee Antivirus )
3 Software problems... Spyware / Virus infections affect the speed of your PC as the "Steal" Proccessing power for their own ends, I have personally seen PCs with terrible Spyware infections that they can barely operate at all, to remedy this I would reccomend downloading the free Spyware tool "Spybot Search and Destroy", (just type into google) and for Viruses you could try using Grisoft AVG free.
I hope this helps.
Posted on Dec 05, 2007
Types of sdram
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
What is the max ram i can put in a pcvrz24g?
The computer is shipped with 512MB Type: PC-2700 Speed: 333MHz DDR and can be expanded to a maximum of 1GB of the above mentioned specifications.
Dec 15, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
RAM problem
computer beeps not booting
May 17, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Does ''FOXCONN 8657MF-series'' supports 400mhz fsb of RAM
Yes, you can add it. The faster 1 GB will be downclocked to the speed of the slower 256MB.
 But it would be better for performance to remove the 256 MB one completely.
May 05, 2010 | Foxconn Computers & Internet
Does Windows 7 Works on D856GSA Board With two 256MB
I am not certain of your processor, but 512MB ram is NOT enough. I GB minimum, 1 GHz Processor. Look here:
Nov 20, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Ram upgrade capability
Simply, yes you can. just open the case and put in the new boards. you can buy higher spec. memory(as long as the pins are the same number)
I.E. ddr-sdram boards will fit and as long as the speed is the same (132.8 Mhz) or higher.
I changed from 133Mhz to 333Mhz and the performance was much improved.
The PC3200 is the important bit, should be the same.
after you change the memory ,try running disc clean up in "start, all programs, accessories, disc clean up" this will also speed things up as well as de-fragmennting your drive(s)
May 02, 2009 | Computers & Internet
I have a GA8ST800 board and I have have been running 256MB ram at 266MHz. I fitted a 512MB ram at 400 MHz. The two together would work fine, even though they were running at 266MHz. I bought two 512MB...
The RAM speed of the new chips is too fast. You need the slower either 266mhz or 333mhz RAM speed to make your system stable again. Hope this helps.
Dec 27, 2008 | Gigabyte GA-8ST800 Motherboard
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
May 27, 2008 | Asrock 775VM800 Motherboard
You have the answer in your question. I have checked the PC specification and you are right, it uses PC2700 memory. Therefore you need to install PC2700 memory. PC3200 memory will be the wrong speed and will not be supported.
Apr 18, 2008 | Computers & Internet
ASUS P5S800-VM Motherboard Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
