Question about Clarion DXZ365MP CD Player
No sound? i have conected all the wires and it was working fine except one of my power wires disconnected so i pulled it out and joined it all up but now there is no sound being produced.. wat should i do? what can i do?
HIya,
Check to see if you have a Reset Button.
Unit may need to reset.
Posted on Dec 05, 2007
My antenna on my 1990 honda accord stopped working after I installed a new radio
BAD CONNECTION? DID YOU PLUG IT BACK IN? OR DAMAGE WIRE? OR PULL OUT FROMM BEHIND DASH
Mar 14, 2013 | Honda Cars & Trucks
When pulling the front brake on the rear brake light stays off...if i pull the front brake the light comes on...
switch on the front brake lever is faulty or wiring fault to it, to check this disconnect the wires on the switch(normally spade connectors) using a paper clip join the two wires together and check to see if brake light comes on, if so replace the switch, if not then you need to check for power on the wires if no power on either wire you need to look for a broken wire or blown fuse i would doubt it if it is a fuse unless other things are not working on the bike.
Sep 06, 2011 | Yamaha MulhacAn CafA 659 Motorcycles
Sony ps x65 when started no sound except very intermittantly tried two different amps any ideas
The most obvious cause could be loose conections to the cartridge. Or even the cartridge itself. If you disconnect the wires to the cartridge and touch them with your fingers (turrntable connected to amp & powered up) you should get a buzz on each channel. If you don't the problem is not the cartridge, but a failure of the wires either inside the turntable or to the amp.
Mar 01, 2010 | Sony Audio Players & Recorders
Car radio doesn't work
It sounds like the antenna wire may have come loose from the radio or the antenna - would be worth checking. Just remember, if you can't get in behind the radio, and you have to pull it, don't disconnect the wiring harness, or you'll need an unlock code to make the radio work again.
Aug 15, 2009 | 2004 Chevrolet Tahoe
I cant join an online game on call of duty 4. when i click find game or try joining friends, it says downloading game...... i know it's not my internet conection because im fine with other games online.
It may sound crazy but alot of people may not be playing when you are or they are playing something else so the the computer(connection) is searching for some players for you.
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
No sound coming from sub woofers amp is connected and powered properly,all connections are correct,i have checked all connections to head unit,to battery i have disconnected and re connected all...
check your amp fuse also any car fuses, then check inside the sub box at the connections as they dont come connected when you buy it, try that 1st
Jul 11, 2009 | Car Audio & Video
No sound output - pioneer DEHP6700MP
Sounds like a grounded speaker, disconnect each speaker and see if the sound comes back on through the remaining speakers connected. Its sounds like it is just in protection mode from a chssis ground. I hope this helps!
May 30, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Foxconn K7S741GXMG-6L Sound issues
maybe the problem isn't in the sound cards or buil-in sound cards, i'm sure it's the speaker your are using, it may have some power leakage or something of that sort... check your electric "ground" connection too.
Jan 26, 2007 | Foxconn K7S741GXMG-6L Motherboard
Clarion DXZ365MP CD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
