Question about Intel D845GVSR Motherboard
Mother Board Problem
I have problem at the time of system start. When i pressed power button on CPU, signal will not transfer to monitor. Only processor and fan wiil run. Please send me proper solution for this.
  • 99 Answers
Is the color of your led monitor orange?if on yes ,try to on the numlock key, if the led idicator lite ,check your video card by replacing it with new one. but if the numlock indicator not lite on when you press the numlock key,check your memory by replacing a new memory.
Posted on Mar 29, 2008
I think that this is Ram problem, firstly you check our computer on another monitor,after that you check ram
  • 661 Answers
Hmmm... Where to start......
Discounting the possibility of a faulty monitor, (I am assuming that you have tested this, either by trying a different monitor or checking the monitor is working on a different PC (Either yours or someone elses that you know)). it sounds like your PC is not booting through BIOS..., this can be caused by all sorts of things, from faulty Power supply to Faulty MEM or even a faulty PCI or graphics card....
The first thing (except the monitor) that I would check is the Power supply.. if you can get your hands on a spare power supply that is the first thing to test (by replacing).
If that does not resolve it's a case of systematically removing all other possible causes of the fault (IE remove all PCI cards and Drives, not removing the Graphics card or MEM.
if the fault persists with all these things done you have diagnosed that the fault lies with the motherboard the CPU or the memory.
Posted on Dec 05, 2007
Monitor does not come on
Hi Scott,
please check the removing the vga cable of monitor and turn its power on and display must show no signal error itself you can see it very clear text on it.
if your monitor good check the cable and plug it back to pc.then turn on the pc.if computer starts you can hear the HDD sound and please note the Beep sounds comes up or not ,if continues beep comes up problem can be with your pc memory modules or vga card ,sometimes mother board,
clean the ram card using smooth brush and mother board also.
unplug the power supply jack and re insert it .
remove the vga card also and do the same.
first all check the power unit fan is turning on when you press the power button too...
please let us know the results or come with more details.
regards.
nuwan
Jan 08, 2014 | Dell Dimension 3000 PC Desktop
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
Hi All, I'm using philips 15 inches monitor. After i press the power button on my CPU, monitor gets no signal. But sometime it get the signal without any issue.This is random failure. I plugged my friends...
HI,
This is not your problem, this is your monitor's problem, just kidding :)
This monitor require re-solding of point on its board. If you can do it, open it and check power circuit and data cable circuit and re-sold points. Hope this will work.
Regards;
Hassan
Jul 20, 2009 | Philips Computers & Internet
Intel D945GCNL Board No display
Dear user, this problem can be coused by many things.
1, The memory you have installed is not compatible with your system.
2, Power supply failure.
3, Contact issue between the socket and the module.
Try thease:
Take a brush and clean the sockets.
Power on your computer without the memory modules, if you hear beep it could be a health signal :D.
Power off the system.
Clean your memory module pins with alachol or other cleaner liquid.
Wail till it dry, inster it back to the socket and move a little ud and down to catch ancontact.
Power on and now shold be work fine.
If this ain't works. Try other brand of memory, kingmax or kingston. They usually shipps with 99 of good modules from 100.
Good luck.
Mar 22, 2009 | Intel D945GCL Motherboard
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
Booting Problems 845 GVSR Chipset Motherboard
it is possible to repair,just check the rate if it is costly then you better take a new one
May 15, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Acre 5520 laptop
Assuming already installed vista.
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
Is it giving any error messages.
Try booting in to safe mode.
If it does then the issue is with something.
Do you have two video adapters.
Try boot from the dvd & run the recovery for vista.
or the system restore from the dvd.
At last run repair reinstallation using the vista dvd.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
Intel D845GVSR Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
