Question about Velodyne DD-18 Subwoofer
Dd-18 no sound coming from it...
Hi there
i have 2 dd-18s in my HT. All of a sudden i amp stopped working and doesn't respond at all, no sound is coming from it, doesn't respond to any remote control action.
the 1 thing i see is a orange line illuminated just beow the velodyne logo in the front of the sub, which is not illuminated in the other sub that is working properly.
can anyone please help me out with this problem????
You could try disabling the auto-on feature or you could try a factory reset or firmware upgrade.
Swap the wires between subwoofers to see if its the wiring.
If its no longer under warranty you could try swapping the amp modules or the fuses, this will tell you if its a fuse or the amp or the driver... however by doing this you risk blowing up the second working amp or voiding warranty.
Last year I had an amp failure on my velodyne and it cost 250 for a 2007 replacement.
Posted on Feb 04, 2008
Onkyo ht RV 330 suddenly stopped putting out sounds
Sorry, I made a horrible mistake.Your av-amp only gives you 2 tick......Tat sounds instead of 3 tick......Tat......tick sounds ,(3rd sound coming from speaker relays never coming out.). Download onkyo htrv330 service manual.
Find out those components and fix them to make sound again717a4e3f-3111-4cac-8ca6-b2e15564b986.jpgp.13 check all yellow circled components-cgclsceegoxl2fmhkzw1bj15-1-2.jpgp.27 +24v supplied to speaker relays-cgclsceegoxl2fmhkzw1bj15-1-3.jpg
Aug 02, 2018 | Onkyo Audio Players & Recorders
Sony bravia kdl-60w600b and trying 2 hook up my sony theatre system ht-m7/ht-m5/ 4 some reason it reckenise the amp but the audio system is active but there is no sound coming out of it plz help me?
Hi
please connect your system through HDMI cable & select HDMI port which is ARC written on led then after connecting press sync on batten & select options for your system this is one step if sound comes through your hi fi then ok otherwise go to av setup & select audio out put sound must come
Jun 16, 2015 | Sony Televison & Video
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
HT-RC180 all of a sudden no sound output (not muted, etc.) Turned it on yesterday, and everything works, but no output. Observations: No static/noise floor when volume is increased to maximum-absolutely...
Hello, I think that I may have responded to you via an email sent to our customer support. If you are not the person that I responded to please email me at askonkyo@us.onkyo.com with your serial number. Thank you, Onkyo USA
Jun 30, 2017 | Onkyo HTRC180
I own a Fisher X-202-B tube amp which I have restored with new caps. It played very well for 2 weeks,then one input section suddenly went dead. It doesnt matter if I use tuner,AUX or phono,there is zero...
i) It is possible that one of the electrolytics has been put in with wrong polarity. Check in the faulty channel preamp. It may have caused the HT to collapse in that preamp section - look for burnt resistor.
ii) Also compare the corresponding voltage on the anodes of the preamp valves in the working & non-working channels. This will tell you which area is faulty.
Feb 15, 2011 | Audio Players & Recorders
I Have samsung HT-P10, Pl let me know the laser lens number is used for the same or let me know any satiable lens which can be used for HT-P10
Hi.. my home theater system HT-P10.... is not working.... Any of its function do not respond after it being kept on...! Any of its function are not working.... the dvd player doest open up.. nor sound comes out of auxiliary, radio or any other function... and the 5.1 display is never shown.. it shows 2 channels only..
and this had been the problem frm last 1year.. at the beginning of the year... it was working suddenly in between and at times it use to turn out inactive but from last 6-7 months it is totally inactive...!
I contacted samsung.co.in and the guys came down to my house telling that we dont hold any spare parts of system we cannot do anythin...a do they say we do not repair...!
So what to do to repair it.. can it be..? nd can i ever use its sond sytem only.. in any form.?
Sep 14, 2010 | Samsung HT-P10 Theater System
Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Feb 19, 2009 | Panasonic SA-HE90 Receiver
Toshiba A105 laptop
Hi Harry! Did you remove the ram? Sounds like it is either not compatible. Good luck!
Jan 08, 2008 | Acer Aspire 5050-3242 Notebook
Output problem
First check all the cables that there is no bad connection.If this doesn't solve the problem your amp is worn out
Jan 01, 2008 | Durabrand HT-3915 System
Samsung HT-DB600
samsung told me the fan is not working and needs replacement or a tune up??? They can repair it for $150.00....totally sucks
Apr 29, 2007 | Samsung HT-DB600 System
Velodyne DD-18 Subwoofer Logo
499 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
