This is most likely the defrost heater in the back of the freezer and behind the panel. Unplug and remove panel and if covered with ice defrost until you can see the defrost heater part number WR51X10055
If you see the defrost heater burned out because it will be easy to spot because glass covers the element inside. You should also replace the defrost thermostat part number WR50X10054, Let me know what you find Thanks, Sea Breeze
Comments:
Aug 27, 2009
- Here are some photos of the defrost heater and defrost thermostat. Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze appliancepartsse@yahoo.com
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. ...
(More)
Need to know how to take off the broken piece of tubing and connect the new. Blue Valve assembly. Should be simple but I just can't see it.
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's...
(More)
need the hose that runs under and internally for my profile. Appears to be 1/4 ID and 3/8 OD. It's brittle and leaking
temperature controls are out. Changed main control board but problem persists. fridge is still...
(More)
temperature controls are out. Changed main control board but problem persists. fridge is still chilling, ice works etc
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water...
(More)
I have a whirlpool side by side and the ice maker doesn't work the arm goes up and down but no water seem to be running
