Question about HTC TyTN Smartphone
TYTN2 buttons not reponding - screen navigation fine
The front buttons and scroll wheel on my tytn2 stopped reponding but the screen navigation works fine. I was told to reset the storage but this did notresolve the problem
  • 1 more comment
  • papa007 Feb 25, 2008
    i also have the front buttons of my tynt2 not working as well as the keyboard except the directional keys. i tried soft and hard reset(clear storage option) , can anyone help.. would it make a difference flashing the whole thing and putting new rom?
  • Anonymous Dec 17, 2008
    I have the same problem
  • BIG PUN May 11, 2010
    could i get a unlocking code for free anywhere.i have the same phone the tilt and need to unlock to use with tmobile please help,,,
  • 20 Answers
If a soft reset does not fix it,
Try a full hard reset:
Soft reset: Use the stylus to lightly press and hold the RESET button on the bottom of your device.
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Another Option if one of the SOFT KEY's is bad: START/SETTINGS/SYSTEM (tab)/CLEAR STORAGE.
Posted on Feb 07, 2008
My samsung juke phone won't work. If I take out the battery and charge it, the screen will flash. The second I press the prongs together, it stops working.
You may need to reset the phone, but it will delete everything on the phone. You may follow the steps below:
  1. From the main screen, press the center of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the center of the navigation wheel to choose OK.
  3. Select Phone Settings then press the center of the navigation wheel to choose OK.
  4. Select Security then press the center of the navigation wheel to choose OK.
  5. Enter the lock code then press the center of the navigation wheel to choose OK.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Restore Phone then press the center of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the center of the navigation wheel to choose OK.
Jul 26, 2016 | Samsung Cell Phones
If my phone have blocked so that it doesnt want to unlock what do i do
You can factory-reset , your phone through custom recovery
what means you can bypass the sign-in problem you have .
NOTE : YOU WILL LOSE ALL YOUR DATA SAVED ON THE PHONE STORAGE !!!
how to : you can go to factory reset by clicking and holding : volume up , home button and power(lock)button simultaneously
soon as you see the logo on you screen you can remove your finger from the Power(lock)button and then you will enter the custom recovery mode , there you can navigate using your volume buttons .
Navigate to Wipe data , Factory reset hit the power button (or home button ) to select , on the next screen navigate to YES and select
wait for it to finish , and hit Reboot .
that's it you shoud be fine .
Dec 30, 2014 | Samsung Cell Phones
Iam was using HTC TYTN 2,it was working fine till yesterday,today moring i dropped my tytn2 in road by accidently,i took it back and my phone was working good i can receive the call and i can make the...
it seems when you dropped the phone some stuff shifted in the mobile if you can pull the phone and just screw it back up it should be ok, if not i recommend contact a technician for his assistance
Sep 18, 2010 | HTC TyTN II Smartphone
My Jandy PDA has stopped working. It started to
need new PDA hand held make sure to replace with same model old ones 800 MHz new ones 900 MHz means change antenna also
Apr 05, 2010 | Jandy AQUALINK RS TELELINK KIT
My tytn11 touch screen does not respond to screen taps. Everytheng else works. Navigation control and all buttons work. Have tried soft reset and screen aligning to no avail. Advice will be appreciated
I have sent my Tytn2 in to have it repaired. Seems as if it could be the screen which has to be replaced at +- SaR 95.00 or the flexi at SaR 650.00. So in a panic I spent the $12.95 to subscribe to this site unnecessarily
Jan 19, 2010 | HTC TyTN II Smartphone
Screen broken on nokia 6210 navigator need info from phone
Dear,
When u connect the phone with the pc, u just scroll down to image the mass storage. i hope, it will be the 2nd option. Go for it and u will be connected with pc for data sharing.
good luck
Sep 09, 2009 | Nokia 6210 Navigator Cell Phone
2007 Honda Civic Navigation Screen went black
Had same problem with 2008 Honda Civic.
Note: you will need anti-theft code so get it first!
Solution:
1. Turn ignition off.
2. Look for fuse box under steering wheel.
3. Remove fuse #35 which is for the Navi-audio unit.
4. Then re-insert the fuse. This will reset the system.
5. Turn ignition on and the Navi-audio on. Buttons WILL be working now.
6. The unit will request for the anti-theft code for Navi-audio system. Enter the 4 digit code....Yippee!
However, I lost all my radio preset stations. Thankfully my saved destinations in navigation system were intact.
Apr 02, 2009 | BoxWave Corporation 2007 Honda Civic...
JASJAM TOUCHSCREEN NOT RESPONDING
Did you find a solution to this problem? I have just bought an I-Mate PDA2 and within 4 days the touch screen has stopped responding, but like your, the scroll wheel and buttons still work. I have tried the full reset and now I am left stuck on the initial set up screen. Any help would be much appreciated. Thanks
Jan 10, 2008 | HP iPAQ H1940 Pocket PC
Button stuck?
or course, powercycle....if that doesnt work, a master reset will be needed.....because it sounds like there might be somehitng stuck on the screen in the corner for make it scroll around, clean the screen with a qtip and rubbing alchohol.....if that doesnt work, try a software reset. with the phone off, you will have to press and hold the button withthe lines on them and press the power button.....release the powerbutton.....the phoen should turn on and go to a black screen with white writing....release the soft keys here and press the green call button...it will reset the phone, but in turn, you will loose your info that is not stored on the sim or media card...
this is hard to do, so if you can navigate through the phone go to start, setttings, system, clear storage. it does the same thing. good luck :)
Dec 31, 2007 | T-Mobile Wing™ Smartphone
HTC TyTN Smartphone Logo
416 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
