FixYa.com
Tags:
Casio G''zOne Type S Cellular Phone
Casio gzone (by 3 users)
posted by Irabing on Dec 05, 2007
hi i just got the casio gzone and i locked it by mistake being that the phone has no number active on it ,it doesnt have a pin that i know of. is there some kind of factory pin i can type in?
Comment by Irabing, posted on Dec 16, 2007
my phone wouldnt unlock after going to a verizon store in a mall. and doing other stuff, so i finally took it to the manhatten store. and they were able to unlock it.
my phone didnt have a number activated on it so i couldnt type in the last 4 digits
but if u do have a phone number than it should work, provinding that u didnt dchange the code.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by squarepants, posted on Jan 05, 2008
Had the same thing happen to me. Bought the phone but before I activated it I pushed the lock button by accident thinking it would activate the vibrate function and now it is all locked up. Tryed last 4 of the phone number as well as many others suggested by the verizon agent and none worked probably because the phone was not activated yet. Verizon tryed to call Casio support but they are only open 9-5 m-f. Anyone know the 4 digit casio default code to unlock the Gzone type-S? Have tryed 1234, 0000, 9999 etc.
Comment by Joe102, posted on Dec 09, 2007
I did the same thing... I pulled it out of my pocket after dropping and it's locked. I've tried everything, but nothing will unlock it. Does casio or verizon have a special pin or code to unlock it?
Best Solution
posted on Dec 14, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The unlock code is the last four digits of your phone number.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 12, 2008
FixYa! (100)
squarepants
Rating: 97%, 5 votes
Sean J,
The only way to get the manufacturers code for your phone is to contact casio support directly by phone. Go to this link for the #'s - http://www.utstar.com/pcd/ContactUs.aspx
They are glad to give you the code for your phone once provided the ESN HEX # under the battery. Only problem is they are only available M-F 9-5.
Once your phone is activated then the code defaults to the last 4 of the phone #.
Solution #3
posted on Jan 22, 2008
Not Rated (0)
jeepin_jules
Rank:Master Master
Rating: 81%, 14 votes
I just called Casio. on my phone I had switched the nam accidentally to nam2 and when the phone reset my original lock code did not work any longer. They gave me the run around for a little while telling me that I would have to send the phone in for repair but then I finally got a hold of one of the techs and he said that 4298 would work. I don't know if it is different for every phone but it may be as he asked me for the hex code on the phone.
hope this helps someone...
Solution #4
Not Rated (0)
Sean J
Rating: 0%, 0 votes
You missed the point though. Some of us have unactivated phones that are locked. Since there is no telephone # attached, the last four digits are nonexistent... what then?
Solution #5
posted on Dec 18, 2007
Not Rated (0)
dakotasky
Rating: 0%, 0 votes
Thanks Guest you rule! last digits worked
Can you Help with these Cellular Phones problems?
no power
phone will not turn on with the... Answer This...
wont turn on
my phone wont turn on all of... Answer This...
phone wont turn on
phone wont turn on, even if i... Answer This...
100% pix message full
I have 17 pix messages... Answer This...
g'z'one
Do you know where to plug in a... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
