Question about Toshiba REGZA 47HL167 TV
The TV will not turn on. Has flashing orange light
I have a 47" Toshiba Regza. I watched tv this morning, left the house, now it willnot turn on. There is a flashing orange light close to the power button. Do you an idea what's going on?
  • Adam Jerome_lagudi
    Adam Jerome_lagudi May 11, 2010
    is this a plasma tv or a lcd tv?
  • 3 Answers
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it.
Posted on Sep 13, 2009
  • 33 Answers
Had a similar problem with our Sony. Unplugging for 36 hours solved the problem
Posted on Aug 31, 2009
SOURCE:
I have a Toshiba regza 42x3030d and turned it on this morning and no tv channels comin thru can still watch DVDs with perfect sound tried to ring Toshiba but closed anyone have any idea wats goin on pls???
Check whether the input selection have been set to AV. If the set plays dvds, and not RF, the tuner to its must be suspected; provided the input selection is done correct.
Nov 17, 2013 | Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Toshiba REGZA 47HL167 TV Logo
3,317 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
