This is the wireing diagram for my 200cc atv, not sure of the make and model yet ,,,,, LOOKS LIKE A FALCON OR RAPTOR,KAZUMA LOL.
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, black wire with white stripe wire
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, green wire
kill switch ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, light blue wire
starter button ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, red/yellow wire
starter button ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, light blue wire
remember their are 2 light blue wire,s so please check , so if its not the 1 from the kill switch then it must be the 1 from the starter button ect.
solonoid ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, left hand side thick red wire to battery
solonoid ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, right hand side thin green/yellow to red yellow starter button.
green form the kill switch to the green on the fuse box
green and red to battery
so 3x red wire to the battery pos and 1 wire for the negitive which get grounded to the frame
3 x red wire with the extented wire wich i used was blue to battery positive
1 x blue wire thats the extended wire join to blue wire the to battery
1 x yellow/green wire to ground on battery
1x red from starter motor to right hand solonoid,
and thats it atv should run ,,,, the only problem i have now is the spark from the spark plug hmmmmmmmmmmmmm
Check coil connection to harness is solid. But, I suspect your start button wiring is bad -- should be replaced (yes, the whole switch assembly).
cranks but wont start no spark changed cdi box but still no spark
