Colors are way off on my screens
I was trying to run compatibily wizard but do not know how. how can i adust these colors? even my printer is printing everything in green, yet i just bought new inkjet cartridges. please help me.
helene alberts
p.s. i am running windiws xp pro and have a lexmark X1185 all in one printer
  • 45 Answers
Umm, im not trying to state the obvious but, have you checked that the colour setting is 32 bit colours (right click-properties-settings-colour quality)? also make sure that the correct drivers are installed for your monitor and GPU (graphics card). check that they are also up-to-date. also check the actual screen menu and make sure the colours are good, fidle around with them (RGB) until they are better (last resort!!!). about the printer...i have no idea!!, check out the properties when coming to print to check its not set as one colour, usually under the colour tab (for some odd reason hehe). check that the colours are equal and that certain boxes aren't ticked, i.e grayscale etc!. hope this kinda helps!
Posted on Dec 05, 2007
How can I adust the printer for even distribution ?
Computer program issue. unless the paper is tracking off. Try Reloading paper and check that rollar is latch rvrnly
Jul 25, 2014 | SATO Cl412e Label Printer
Printer needs to be on the wireless network, then setup the PC with printer wizard using the IP to identify the printer. You may even try entering it in the Run / Search for auto setup by Windows. Both have to be on same network.
Nov 26, 2012 | Epson Stylus Nx420 Color Ink Jet...
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Netgear ps121 won't print
Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
May 01, 2009 | NetGear PS121 Print Server
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell 964 all in one printer
During the photo printing wizard, in printing options window, choose the printing preferences button. Once you are there, choose the maintenience tab located on the top of the screen. Choose the clean print cartridges button. Hope it works!
May 21, 2008 | Dell Photo 964 All-In-One InkJet Printer
Color printing from Windows XP Photoprinting Wizard
Just dirrerent intrepertations by the driver.
Often times "auto" settings are not the best to use.
You can default it to the best management solution for your computer/printer matchup.
Sounds like a weasly answer I know, but it is amazing how much different those will operate one system to another.
Another suggestion, color normally prints better with a PS, Post Script, driver then a PCL , driver. You may want to go ont the website for your printer and see if there is more then one driver, and switch drivers to see what happens.
Subtle differences in drivers can make a difference how printers print also.
Most of the times it's finding where your printer works best.
It is not necessarly a problem if one setting works better for you over another. Just nuances on different systems.
Please don't take this as a wise comment, but that is why all those adjustments are on drivers and printers, sometimes you just have to modify to get what you really want quality wise.
Hope this helps.
Feb 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Prints black page
Click Start - All programs - HP - HP Director/Solution center
Click Settings - Print settings - Printer settings
Click on the Colors. In Color Management select "Managed by Application". Click Apply and OK. Close HP Director/Solution center.
Try printing.
Jan 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
