Question about IBM ThinkPad T30 2366 Notebook
JerkyDisplay Hi all, i'm now typing this on my flickering T30 screen. it was workign fine till about 2 days again when it started "jumping" and "vibrating". At times, it wld be stable and fine and at times the screen image would be "vibrating non-stop". I have tried starting it up in safe mode, load my drivers, updates BIOS, etc but the problem doesnt seem to go away. I have tried displaying the image on an external monitor and it's the same. However, the screen only jumps and jerks when i'm in windows, when the system is booting up and when the "window logo" comes up, it doesnt jump and jerk. Anyone have another answers? Is it an overheating problem or some problem with my graphics "card"? is there a card that i can replace or is it integrated? Thanks in advance.
  • 38 Answers
It May also be caused if your screen is in an external magnetic field.Just try it at any other location and report it please.
Posted on Dec 05, 2007
  • Mohammed Talha Deliwala
    Oh I forgot to add more
    You report that the screen does not jump after windows start up then there is a solution format the drive where the windows is installed obviously using a startup disk.Reinstall Windows.Make sure you take your backup before formatting and format that drive completely.
    If that solves the proble rate me please ;-)
Bad alternator or something more simple causing 2004 Escape to die/not start??
you can drive even if your alternator is not charging but your problem is you have a posetive wire touching the body sumwhere trace your wires properly n u will find the problem
Oct 21, 2012 | 2004 Ford Escape Limited
Wont start without jump and has new battery
You have a draw that is killing the battery. Search for more answers under battery draw.
Oct 18, 2012 | 2008 Dodge Nitro
New alternature wont charger battery
if the alternator is testing great replace the battery
Jan 01, 2018 | Cars & Trucks
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Hi i have a 2002 lincoln continental with 31000 miles car doesn't start if i use a jump starter car starts and keep running for the time you deserve i test the battery and looks fine i test alternator and...
I have a 01 Lincoln Continental that wouldnt start. After paying $69 to the repair shop they told me that the alternator and belt are working like they should but the battery wont hold a charge. I took the battery to Sears (6 month old Diehard) and after a day and a half they said the battery is good. Now the car starts each time but the lights(inside and out) all flicker and when you press the gas they flicker more? After about 5 minutes the flickering stops. What could be the problem?
Dec 28, 2010 | 2002 Lincoln Continental
Speedometer doesnt work and it wont shift
Check the speed sensor again and make sure that the wire harness is not damaged in any way. Go to a Auto Zone and have them rescan the DTC codes and see if the VVS has gone bad from time to time in the history. Check the wire harness to the ECM on the passenger side in the engine compartment by the overflow tank. Make sure there are no damages to the clips and wires. Other then that it could be a bad sensor that may have been installed. Good luck and hope this helps.
Aug 04, 2009 | 1997 Oldsmobile Bravada
Screen jumping on acer aspire 5920
First boot in safe mode and the display resolution will be minimal if the screen appears ok with big fonts then try and adjust the normal resolution but not high resolution like 640x480 with 256 colors, if it works then you acer laptop screeen is fine but the exactly display drivers to be reloaded else there is a problem with your laptop screen which needs to be replaced
Mar 18, 2009 | Acer Aspire 5920 AS5920 Notebook
IBM ThinkPad T30 starts up, then turns off
Motherboard is damaged I recommend ebay for a board of that type, there is no simple fix I own three T20s and when one did the same thing I just replaced the motherboard that solved the problem. the lcd screen and inverter were fine.
based on the non powering issue now I would say the MB is shot, replacement will give you a few more year use however for a reasonable price.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
170 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
