Question about Amplifiers & Preamps
B&K Components AV6000 Series II Power Amplifier 3 channels out
I have a B&K Components AV6000 Series II Power Amplifier that has 3 of its 6 channels out. I need a wiring schematic. A friend at work used to repair amplifiers for a living in Portland Oregon and said if he had that he could fix it.Thanks in advance for any help, Linas
3 Suggested Answers
  • 363 Answers
SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
Posted on Sep 22, 2007
  • 4234 Answers
SOURCE: i need the schematic for the crown amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Posted on Jun 29, 2009
  • 3614 Answers
SOURCE: Require a users manual for :Sony-STR-KSL40-Dolby-Proligc-II-Ampli
Posted on Sep 21, 2009
0 characters
1 Points
Distorted sound
Distorted sound can be caused by at least 20-30 different issues. Just for starters: 1. What amplifier are you using? 2. What speakers? 3. What audio source? 4. What cables? 5. What power source? 6. How are your individual components connected together (configuration)?
Mar 04, 2015 | Amplifiers & Preamps
I need a face plate for a Sunfire Cinema Grand Signature
try this, they have several types...meder's tv service
Sep 10, 2012 | Sunfire Cinema Grand Signature Series II...
I have an EP2500, which burns speakers. I connect with a lamp in series, and when it receives high frequency signals, lights the lamp, the output looks correct, but consumption is increasing dangerously....
There was an suggested solution here for your problem.
There are electronic components which seems to be undiscoverable
for a moment.
• The fault could be anywhere from the differential input stage
to the VAS circuits.
• One has to check thoroughly components , and proceed
troubleshooting without the power transistors connected.
• Check for offset voltage on each of the main amp output.
• Check for idling current
A good amp never produce an over of 0.7V on its output.
Jul 30, 2012 | Behringer EUROPOWER EP2500 Amplifier
ADCOM7500 how to use it?
Good gift. It is a 5 channel power amplifier and I do not recommend to connect any sources directly to it. Now you need to buy a preamplifier/ receiver from Adcom GTP series or other brand to connect you dvd player, cd player, cable box, playstation etc. you need 5 good speakers to get your surround sound (or 2 for stereo)
Dec 28, 2011 | Adcom GFA-7500 5-Channel Amplifier
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
Need help understanding amplifiers
Take a look at Marantz's ZS5300 6 ch amplifier. that'll give you 3 stereo zones. Good luck!
Dec 13, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
How to set up an intigrated amp to a 100 watt reciever
audio connection must have matching in audio level and symetrical.
1-prepare your connection cabels(better to be colour marked at connector(red for right channel- white for left chanel).
2-take pre amp right out to power amlifier right in.
3-take pre amp left out to power amplifier left in.
4-connect amplifier right out to right loudspeaker.
5-connect amplifier left out to left speaker.
6-adjust volume level and enjoyyy.
Feb 26, 2008 | Amplifiers & Preamps
Amplifiers & Preamps Logo
94 people viewed this question
Top Amplifiers & Preamps Experts
Are you an Amplifier and Preamp Expert? Answer questions, earn points and help others
