Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Hdd installation my mobo ( Gigabyte 7VM333M-RZ)          does not have sata 1 or sata 2 connections,so i want to know that a 320GB hard disk can be supported by it or not ,i will be using xp sp2 or in future vista ultimate. Or if not then how much of capacity in GB hard disk can be supported by this mobo
  • Anonymous Aug 17, 2008
    hi i am patel kamlesh
    my giga mobo is not supported two sata hard disk if connecting two sata hard disk else my pc hes randomly restart. how problem in my pc.
  • 661 Answers
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Posted on Dec 05, 2007
I have audio drive problem
Just click this site link to download your Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard sound driver. then choose your present Operating system. to download right sound driver.
I hope can help.
Sep 15, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Windows can not detect the sound device; the motherboard is gigabyte 7vm333m-rz
reinstall audio driver from your motherboard disk, if will no resault, enter bios, from there turn on audio device , maybe written AC97
Jun 02, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Machine boots gives a startup beep then blue dump which fades to black screeen.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Mar 19, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Ihave gigabyte tvm 333m rz mother board suddenly there was no out put to monitor
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 12, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Will gigabyte 7VM333M-RZ support 1 gb ddr2 ram ? thanks in advance for your answer
this information is from Gigabyte web site
  • DDR 333 (PC2700) / DDR 266 (PC2100) / DDR 200 (PC1600) 184pin
  • 2 x DIMM slots up to 2GB
For more information you can also visit the same
good luck and do rate if got help
Dec 04, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Will this motherboard support 250 gb harddrive ide seagate
is it SATA? it shouldn't have a problem with hard drives unless the plugs are different. if the HDD is sata and you got a sata connection on your motherboard then you're all set
Feb 21, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Mother board problem
need more info. ? have you tred other drivs. ?
Jan 07, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hard disk
This will help you.
Dec 28, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Upgradation for vista
Gigabyte 7VM333M-RZ - motherboard - micro ATX - KM266
There is a cool way to find out just what it takes to run Vista on your current system. Download and run MS Windows Vista Hardware Assessment. It will help you prepare and suggest just what you need to upgrade either hardware or software. Make it simple! Download below.
Dec 11, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hard disk installation
Bummer I couldn't even find that MB on Gigabyte's site, however a more to the point question for you would be: Are you going to use a XP operating system? If yes than down load the drive's Mfg disk software. Usally you can than creat a boot disk to setup your drive. Pay attention to the jumper settings listed on the drive. If its a PATA drive = serial ATA-133/66/33 you will need to set the jumper for a master or slave or master with a slave. If its a SATA and your board supports SATA II you will need to remove the jumper to allow up 3.0gig transfer rates. If your board does not support SATA II than leave the jumper on. If your board does not support SATA I = 1.5gig tranfer rate, than you can not use this in your system.
Dec 04, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
97 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
