Question about Relisys TL 700A (White) 17" LCD Monitor
Monitor display problem
My monitor HCL HCM780M always displays the monitor menu list (brightness,contrast size etc) automatically...... This troubles me a lot.... Can u help me in solving this problem...
  • 1 more comment
  • jmatampa Dec 09, 2007
    I have the same problem with my SDM HS75P 17" LCD Monitor. The Menu display on the monitor continues to pop up in the middle of the screen. I moved it off to the upper right side but now a small Information window pops up in the middle of the screen and won't go away unless I press the input button on the monitor...but then it returns shortly after.
  • Anonymous May 23, 2008
    i have the same problem , please get it fixed
  • Anonymous Nov 30, 2008
    I have a HCL Monitor HCM780M and the monitor pop up keeps coming again and again .. please help
  • 3 Answers
I have fixed this problem (I think). I noticed That if you hold the menu button down and swith the monitor off and on the box goes, as soon as you let the button go it appears again. So I have jambed the button in with a slither of plastic cut off an old credit card turned it off and on and it appears to be OK. If it holds up I will super glue the button down. Better than someone elses suggestion which was 'Buy a new moniter' very helpful!
Posted on Jan 29, 2008
  • 106 Answers
It seems that your menu switch is short. If you can open up the Monitor check out the connection of your switch and the related components, clean with Spirit or alchohol, check out the switches, if found faultty replace it. That should solve the problem. Good luck.
Posted on Dec 06, 2007
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Contrast Ghost
This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Good Luck
Sep 02, 2009 | Computers & Internet
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Onscreen Display is always ON
usually this is controlled from a small separate board you can find them on ebay for about 20 dollars.
Jun 22, 2008 | Samsung 793S 17" CRT Monitor
Relisys TL 700A (White) 17" LCD Monitor Logo
259 people viewed this question
Top Relisys Computers & Internet Experts
Marvin
Marvin
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
