ASUS P4P800 SE  Motherboard
Problem for ASUS P4P800 SE (890552603657) Motherboard
Possible short on motherboard
By rjagroopsing on Aug 27, 2009
I have a motherboard problem (ASUS P4p800 SE).
When the main power connector is plugged in the board is
powered (indicated by cpu fan spinning just fine), however, if i try powering up with the 4 pin power connector in place it's dead. Sometimes the fan might kick forward ever so slightly. I obviously assume it's a short but can this be repaired? and more so can I repair it at home?
Comments:
Aug 27, 2009
- hi Krishmaqvan, thanks for your resp. At the very least you've given me hope :) will try these methods when I get home from work and let you know how it turned out.
Best Solution
posted on Aug 27, 2009
Helpful)
MNfisherman
Rank: Wiz
Rating: 85%, 2847 votes
You can look for faulty components on board with an ohmmeter on the ohm setting. Check each connection to see if there is any resistance ratings.
Comments:
Aug 27, 2009
- sure can with a soldering iron and some solder.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Hi, thanks for responding (and so incredibly soon!!) I pretty much know it's the 4 pin connector, but can these kinds a things be fixed? at home? " - rjagroopsing
Solution #2
posted on Aug 28, 2009
Very Helpful)
Greg_1979
Rank: Guide
Rating: 99%, 7 votes
It may just be the power supply. That can sometimes be tested by a good computer store. Other wise the only good test is with a new power supply. That's cheaper than replacing the main board and figuring out its the power supply. And yes, the power supply can easily be replaced.
Was this helpful?
Yes
No
Solution #3
Very Helpful)
krishmaqvan
Rank: Wiz
Rating: 85%, 240 votes
First pull cmos cell from motherbord for 10 minutes .
So all settings of bios are back to factory defaults.
Then check.
If till face problem Reconnect ATX connector to motherbord from smps.
Some times this problem occurs becasue of SMPS it is square box on back top side of cpu .
Change it then check.
Some times bord grounding problem.
So open your motherbord and check it in out side of cpu .
Let me know if you need more assistanse.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for ASUS P4P800 SE Motherboard
Questions and Unsolved Problems for ASUS P4P800 SE Motherboard
Do you recommend ASUS P4P800 SE (890552603657) Motherboard?
Answer
Answer
Poler Expree O gauge Train, working all morning..Train goes arou7nd but the throttle is not... (More)
Answer
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an... (More)
Answer
how do i activate my built in web cam on my laptop. it is an acus..
Answer
I have two laptops on one laptop when i plug my pinnacle movie maker into the usb the green light on... (More)
Answer
Cuando enciendo la computadora , me sale una pantalla az?l con el c?digo p4p8oos-x . No entiendo... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
