Question about Sanyo DRW-1000 DVD Recorder/VCR
Help my problem is same as #1 froze while recording will not accept any type of disc....my question i have a lot of discs not finalized,, is there any other make or model which i can finalize the discs with
    President:
  • 4,402 Answers
No but if you need it real bad there is a program called CDRoller or Isobuster might work
Posted on Feb 07, 2008
RECORDED DISCS NOT PLAYING BACK ON OTHER DEVICES
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
Oct 25, 2011 | Televison & Video
Will not accept nem rw disc to record to
then u have kept the settings to finalize disc
u need to change the settings.
Jun 19, 2008 | Televison & Video
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Error message can't record on disc
I would try to burn at a lower speed. If this doesn't work. Try to burn the cd but don't finalize it. If this goes through fine then try to finalize the cd.
Joe
Mar 17, 2009 | Computers & Internet
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
My JVC DR-MV7 will play most DVDs and even record, but recently, it stopped being able to finalize. After I get the message saying "finalization has failed," I can't even play the DVD anymore - thus losing...
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
Nov 27, 2008 | JVC DR-MV7 DVD Recorder/VCR
Panasonic DVD player won't finalize
You can try a dvd+r disc. Borrow one before buying a stack of them.
The other thing is that you may not have enough free space left to burn the finalization track; 7 1/2 hours is a lot of recordings.
Give the +R disc a try even though it says it can't use them in your documentation, a lot of users report it works anyway.
Please don't forget to rate all of our solutions here on the board. Thanks.
Regards,
Worldvet
Jun 22, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Sanyo DRW-1000 DVD Recorder/VCR Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
