Question about KWorld DVB-S 100 (DVBS100) Video Capture
No sound when I coonect my PC through tv
Hi - I have connected my pc through my tv but have no sound! The pc has no speakers with it, so I think this is probably the reason because it thinks it should play through them. Is there a way I can play the sound through the tv speaker.
thanks
  • 35 Answers
Are you using your tv as a monitor, and you have the kworld dvb-s 100 installed on your pc?
Posted on Dec 05, 2007
  • Rodrigo Gallego Dec 05, 2007
    Go to the nearest electronic shop and look for a 3.5 mm earphone jack cable with an RCA jack on the other end. plug the 3.5 mm earphone jack to the audio output of the tv adapter and the RCA jack to the audio input of your TV. And your problem is solved
This doesnt make sense your plugging one thing from your tv back into your tv where does the pc come into this.......
Posted on Feb 02, 2008
What connectors do i need to get my pc on to my tv with sound
If your TV has RGB port IN, you need VGA cable to connect VGA from pc to tv. If your pc has sound card with stereo output. Use an active speaker connected to audio output of pc.
Regards,
Jan 26, 2011 | Computers & Internet
In device manager there is yellow sign on PCI simple communications controller. How to update. I coonect headphone but still speakers of laptop giving sound
Hi!
When you see PCI Simpple communications controller, it normally points to the built in dial up modem on a laptop.. You can download the modem driver from toshiba suuport site..
Hope it helps.! :D
Sep 11, 2010 | Toshiba Computers & Internet
How do i connect my adventt9101 to my sony lcd tv, i want to use hdmi leads but i dont think my pc has hdmi port? any help
If you don't have an HDMI connection on your computer, then you will need to get a VGA cable. There should be a VGA connection on your tv. Just disconnect the monitor on your computer and connect the VGA cable from the computer monitor port to the VGA port on the tv. You may have to set the tv for PC or Aux input. You won't have high definition or sound to the tv with a VGA cable though. The sound will still come through your PC speakers.
Jun 25, 2010 | Computers & Internet
I have some logitech Z4 computer speakers
If your TV has a headphone socket, then plug the speakers into there, then (you have to do this for some TVs, but not others), go into the set-up menu and turn the headphone volume to 70%. Switch on the Z4 and sound should come out, assuming all connections are correct.
Jan 03, 2010 | Logitech Z-4 Computer Speakers
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
There was a spark in my woofer and my woofers volume stopped working also due 2 tht my pc volume also is not working.i installed my motherboard cd but still pc volume is not working.also my woofer is...
good day sir, there is a chance that you PC audio port is also busted( the green port) you may use the blue port, but you should enable 4 speakers (usually rear speakers) on your volume comtrol properties , (or 6 speakers if you want to use the pink one). If still no sound on all ports, buy a new PCI sound card. Coonect it on any available PCI slot on your PC. then run the CD device driver.
Oct 20, 2009 | Computers & Internet
Hi there i am trying to connect a samsung lcd monitor to my pc via HDMI. i have the connection showing picture on my tv, however where i connect a 3.5mm jack from pc to tv no sound comes out. i have...
The connection to your tv is video only. You should hear sound coming from computer speakers. Unplug them and hook your stereo to that plug in.
Oct 04, 2009 | Computers & Internet
Surround System for TV
As far as i know you are unable to connect your PC and T.V to your PC sorround system sorry.
Dec 28, 2008 | Logitech X-540 Computer Speakers
It is possible to connect 4.1 Speaker to Laptop
maybe the type of the sound card on the laptop is not compatible with with the creative speaker system.try to play other speaker systems
Nov 09, 2008 | Creative Labs SoundBlaster Live Dolby...
KWorld DVB-S 100 (DVBS100) Video Capture Logo
121 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Alun Cox
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
