Brother SX-4000 Typewriter
Problem for Brother SX-4000 Typewriter
SX 4000 Brother Electric Typewriter
By stalaro on Aug 27, 2009
When I type it does not come up on paper. I have changed the ribbon & correction type. I reset the typewriter. Everything was working fine, but now nothing shows
Best Solution
posted on Aug 27, 2009
Helpful)
komguy
Rank: Guru  Brother Expert
Rating: 90%, 1224 votes
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" I tried this & it did not work. But your advice was helpful & timely " - stalaro
Popular Solutions for Brother SX-4000 Typewriter
Questions and Unsolved Problems for Brother SX-4000 Typewriter
Do you recommend Brother SX-4000 Typewriter?
Answer
Answer
how to change the margins on a Brother SX 4000
Answer
when i turn on the typewriter it just makes a loud beeping noise and nothing will move
Answer
Black ribbon does not advance. It is the correct type, installed correctly. Have changed it, changed... (More)
Answer
I need the owners manual for my Brother Electronic Typewriter AX-12
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Brother SX-4000 Typewriter:
Top Typewriter Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Typewriter Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
