Question about Samsung Washing Machines
My Samsung dryer machine spins few seconds then stop.....error code t35 appears.What causes it?
    New Friend:
  • 88 Answers
This code with the "T" is temp. related. make sure the lint screen is clean and the vent that goes outside is clear. Sometimes animals build a nest in the vent and clog it. if all looks good and before you call service tec. pull out dryer, disconnect the hose for the vent. unplug the dryer for 5 mins. Plug back in and then try. If still a code it will most likely be a temp sensor of sorts.
Posted on Jul 12, 2019
SOURCE:
  • 135 Answers
SOURCE: E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • 100 Answers
SOURCE: error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Posted on Feb 11, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: samsung WF7708N6W not draining. code 5e & 4e
code 5e showen washing want spin
Posted on Aug 15, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine
well the error E15 means that the dryer thinks it's overloaded. Spin the tub by hand and make sure it's spins smoothly. If so then you have a bad motor unfortunately.
May 27, 2015 | Dryers
Tip
UE Error Code for LG Washing Machines
If you are getting a UE error code from your LG washing machine then you need to know what is causing this code. This UE error code is caused when there is an unbalanced load condition sensed by the washing machine. There are a few things that can cause this and ways to correct it.
If you are doing a load of wash that is too small, this can allow all of the wash to be on one side of the drum. Single heavier items will not work well and will cause this error when spinning. Very light single items may work, but for heavier items you will need to add more to the load to get it to work properly.
If you have a load of heavier items like blankets, and sheets, you may have to stop the machine and spread them around the drum evenly before it will spin properly. Even jeans, shirts, and pillow cases can sometimes all end up on one side of the drum and cause it to become unbalanced. After spreading the items around the drum evenly, try to restart the spin cycle.
If you hear your washing machine slowing down and tumbling a few times when trying to spin, it may be that you machine has a option on it that tries to redistribute the load on its own if it senses an unbalanced load. The machine will try this a couple of times before it will stop and give you an error code.
If you need to reset the code at any time you can do this by unplugging the washing machine and then holding in the start/pause button for 5 seconds. Plug the washer back in and the code should be clear.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Getting error code LO and the door will not unlock
To unlock the door on most Samsung Washing machines:
Press "end of cycle" for over 5 seconds or press "options & select" until the light goes off.
Else, try holding the buttons "dry" & "spin" together for a few seconds until the lock goes off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 24, 2011 | Samsung Washing Machines
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
De1 error message on Samsung front load washer
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
May 30, 2010 | Samsung WF419AA Front Load Washer / Dryer
Code EC appears on my washing machine few seconds after started
Ec indicates a problem with the thermistor or temperature sensor.
Repair and service your own washing machine.
kindly check them out....
thank you have a nice day
Jun 02, 2009 | Samsung Washing Machines
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
