Question about Samsung HT-DS610 System
Error F61 can you please tell me the problem as it turns straight off as soon as it turns on with that message
  • 5 more comments
  • wmmm Dec 08, 2007
    as i push the power button....it shows( F61 ) then goes off
  • Anonymous Apr 01, 2008
    As soon as I turn on the system it says "error F61" and shuts off. What do I need to do??
  • andrew wilson Apr 01, 2008
  • Jayden06 Apr 07, 2008
  • pantz Apr 11, 2008
    same f61 problem with the ht995w dvdplayer.. now the system is out of warranty its going to cost $66 just to make a quote to fix..anyone else had it fixed by service pls tell me how much they were up for? mite be cheaper to replace? thnx
  • Casino777 Apr 14, 2008
    I also have a Panasonic SC-HT920 and I get the same F61 code after the unit shuts down. The manual says bad speaker connections or a pwer supply problem. I've rewired the speakers and I still get the same result.
  • jakenne May 06, 2008
    I have a one year old HT440 system and it jsut developed the same problem.
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Posted on Apr 14, 2008
    Problem Solver:
Error F61 in Panasonic and technics that mean the regulator Ic is faulty.
Posted on Oct 03, 2008
Buy a Bose unit you bloody queef *** bubble with anal leakage
Posted on Sep 25, 2008
The power unit is spolit..try replacing it or fixing the IC..
Posted on Apr 12, 2008
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
F61 error
The F61 error indicates that the unit is in "protect" mode. This means that an error condition was detected in the amp section and the unit has shutdown. This is usually caused by a defective amp chip. Expect a parts cost in the range of $60-$90.
Dan
Dec 05, 2008 | Panasonic SC-AK17 Shelf System
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
F61 error
The F61 error message is effectively a "protect mode" message indicating that a problem was detected and that the system hasbeen shut down to prevent further damage. This is typically caused by a bad output amplifier pac or regulator. If you can post the specific model number, I'll try to get you the part numbers and costs.
Dan
Aug 16, 2008 | Panasonic Home Theater System System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
Samsung HT-DS610 System Logo
463 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
