Question about Kenmore Washing Machines
My washing machine Kenmore HE2t has a Code 3H. Door is locked with load inside
    New Friend:
  • 88 Answers
Unplug or turn the circuit breaker off for 2 mins.
Repower the unit.
Press the Pause/Cancel/Stop button twice to clear the code. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Hope this helps
Posted on Jul 12, 2019
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: KENMORE HE2T WASHING MACHINE
"F25" is a tachometer error. If the control unit is unable to detect the proper motor speed, the machine will shut down. You can attempt to unplug the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to correct momentary glitches. If the error reappears, the manufacturer recommends the following:
1. Check the wiring harness between the Central Control Unit, Motor Control Unit and Drive Motor to ensure they are all connected properly and not broken or loose. This would be connections L2 and N1 at the MCU and connector MS2 pins 1 and 2 at the CCU. (There is a wiring diagram inside the washer behind the lower kick panel).
2. Verify the Drive Motor is turning and the motor windings are good. Resistance checks at the drive motor connector acros Pins 1 to 2, 2 to 3, and 1 to 3 should all read about 6 ohms.
I hope this helps you.
PS I believe the tachometer is a physically attached to the drive motor.
Posted on Nov 12, 2008
Krazytech
  • 725 Answers
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
Posted on Sep 23, 2009
  • 92 Answers
SOURCE: Kenmore HE2T Front Loading Washer Leaks From Door
there is a dispenser hose that goes in the tub.alot of times a sock or something gets inside that hose.that would cause your trouble.take the boot off the front and look up and left to see that hose.it comes out of the tub pretty easy.
Posted on Feb 04, 2010
  • 57 Answers
SOURCE: how do i replace the pump in a kenmore he2t front ...
The outlet pump can be easily identified by reverse tracing the outlet pipe most of the unit will have at the back of the unit so remove the back side cover you can see the pump two clips will be present one from the drum and another is connected to the outlet pipe just remove the clips then two screws will be presented kindly remove those to unfix the pump from the machine then you can easily replace the pump
Posted on May 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: No Power and door is locked w/load inside
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a kenmore he2t washer that will not start. Door locks, buzzes for a minute then shuts off. No error codes. What could the problem be?
the door interlock is basicaly a heated switch
it locks then hold it locked
but there is a sensor to check its closed in the first place
i think the interlock sensor isnt right
replace the door interlock is the first step
http://www.ebay.co.uk/itm/WHIRLPOOL-SPORT-MAYTAG-EPICZ-KENMORE-HE2-Door-Lock-W10253483-46197023640-8540772-/141476775106?pt=LH_DefaultDomain_0&hash=item20f0ac44c2
here is one i found on ebay
its not cheep so shop around a bit now you know a few equivelant types .,.. and models
Dec 07, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Washing machine will not turn on it shut off
Have you tried unplugging the unit and waiting for a minute and then plug it back in. The load might have been off balance and caused that condition. Once it has been reset you might be able top end the cycle.
Dec 07, 2017 | Kenmore HE2 Plus Front Load Washer
Feb 03, 2010 | Washing Machines
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he2t error code 21
Sep 23, 2009 | Kenmore Washing Machines
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
