Question about Ricoh Office Equipment & Supplies
Reason why my laptop cannot connect wireless to my Ricoh printer
  • Ricoh Master
  • 27,904 Answers
Your computer is not connected to your home network, your printer is not connected to your home network. That is the way they communicate.
Posted on Jul 11, 2019
SOURCE:
Cannot connect to wireless network
does it have wireless capability? most ricoh/savin/lanier/gestetner machines must have an option installed.
if you have it networked via lan port and have a wireless access point on the same network you should be able to ping the unit and access the gui. if so it is already "wireless" in a sense
Feb 05, 2016 | Ricoh Aficio SP C830DN - Printer - color -...
Please what kind of wireless dongle do i need to get to connect my Ricoh MPC 3503 wireless and how do i connect it
Just a router and use the same network on both device. Once you had set up the router, you're printer must connect to the router via WiFi, and whenever you want to print anything, make sure that the computer is also connected to that same router. You must have your printer already configured with the computer, otherwise it won't work.
Feb 22, 2015 | Ricoh Office Equipment & Supplies
How do i set up ricoh mp201on wireless network
you will need to plug in to wired network, disable dhcp and configure a ip address within your router range, then make a note of ip, reserve ip in router, removed wired connection and test on wireless.
Thats is all done.
Nov 01, 2013 | Ricoh Aficio CL1000N Printer
I can't scan to a folder on my laptop via a wireless connection from my ricoh aficio 1600. What do I need to do to get my Ricoh to recognize my computer?
questions 1st are you able to print to the copier by wireless ? 2nd was ever able to scan to folder on your laptop by wireless ? If the answer to both is yes try and plug your laptop into a network jack with a network cable and see if you can scan then. If you still can't it is possible the path to your folder has changed or your permission (password) has changed to your folder or the folder is not there anymore.
May 20, 2010 | Ricoh Aficio MP 1600L Black and White...
Network problem with Aficio 1515f
Sounds like you have a wireless router, but are (for some reason) plugging your laptop into it, and if it's not wireless, you should return it and get a wireless one for about the same money, that will let you use your laptop from anywhere, and the setup is often easier, as it can usually all be done via the Installation CD. You can also still plug the Aficio 1515 into the router and print wirelessly to it from your laptop, once you have it configured.
Next, the Aficio 1515 printer feature included a standard usb port, so I find this a little strange.
You can download the manuals here:
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
The 'network settings' guide will be most helpful. The two things you primarily need to be concerned with are the "IP address", and "subnet mask". Do not use "Auto", but rather set them manually, and then configure the printer driver
If you don't have a basic understanding of IP addresses, and network printing, then you'll really need some help to complete the setup
Mar 02, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Need to attach richo aticio mp 161 to laptop
I need to know if the printer is on a network, if it has USB, or just parallel connections. I also need to know if your laptop his parallel or just USB and if it's on a wireless or a wired network. Thanks.
Oct 29, 2008 | Ricoh Office Equipment & Supplies
I want to install my mutifunction machine on network
You need to connect the RJ45 cable from the copier to your router, and give the copier the appropriate IP Information. You can then use the drivers avaliable on the ricoh-usa website to install the drivers on the laptops.
Aug 08, 2008 | Office Equipment & Supplies
I need to print from my laptop, will I have to buy an wireless adapter?
No reason why you should. Run printer software on laptop and connect cable between lapptop and printer when told to do so. Cable needs to be connected everytime you want to use printer.
Apr 26, 2008 | Compaq Presario 700 470024-192 Notebook
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
