Question about Whirlpool Washing Machines
Hi my whirlpool washer would not spin dry,washes clothes,when it is time to spin you will hear the motor humming,the tub make a jump but will not spin, it goes through that cycle and then the humming stops.
    New Friend:
    Problem Solver:
  • 7 Answers
Broken belt.
Posted on Jul 12, 2019
SOURCE:
  • 1294 Answers
SOURCE: whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Posted on Apr 25, 2007
SOURCE: washes clothes fine, drying cycle no heat
Hi, we had the same problem with a WD420P. After a washing machine repair man plugged in the diagnostic machine and found that there was no fault, my boyfriend had a look. The nut securing the cooling fan inside the heater element was not tight so the heater overheated and tripped it's stat. This was a 5 month old part fitted after the original was replaced under warranty.
Posted on Jan 14, 2008
SOURCE: Whirlpool washer won't spin even though motor is running
Sounds like the the motor belt is worn or off. Try a new belt, or check the drain pump filter for clogs.
If you've got a handy friend, it's easy to check these... remove the back of the washer (about 12 srews) and check for black dust inside, or a belt hanging or lying on the bottom.
To check the drain pump filer screen, look for the drain hose, follow it into the back of your washer and down to a plastic bow looking unit. There should be a round cover with a kind of handle on it. remove the cover, (water may run out... have a few towels handy) clean off lint etc. and put back together. Try again...
Posted on Feb 07, 2008
SOURCE: Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Posted on Feb 27, 2008
bestdarngood
  • 3037 Answers
SOURCE: Clothes don't spin dry enough
Is the heating element working, have you tested it or noticed whether your clothes are coming out warm. It may have gone bad and needs replacing. Let me know if you have questions with this or need a place to buy the part. There are many online sites that will sell you a new element
my best to you
Posted on Aug 08, 2008
I have top washing machine,will not spin out the clothes.Tub will not spin.You can hear the motor running
You probably need a new coupling. It is the part of the washer that allow the motor to turn the transmission. The part number is 285753A it will cost about $20
Jul 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 plus series spin dry is not working
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Sep 30, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Jan 17, 2010 | Washing Machines
The spin cycle does not get the clothes dry enough for the dryer. I have to rerun the spin cycle after every normal wash, rinse and spin.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 16, 2010 | Washing Machines
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Washer motor spins but the TUB does not (intermittent)
If the motor is running and the tub is not spinning you must remove the motor and inspect the drive coupling.
One of the 2 plastic pieces could be stripped or cracked.
If the drive coupling is intact, proceed to the clutch on top of the transmission.
Replace the clutch linings.
Mar 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
23 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
