Question about E-Machines T2893 PC Desktop
Will not turn on
Computer was fine, unpluged it to move to a new state, now it will not even turn on. not sure what to do, tried new power cables???
  • 1 more comment
  • R1K9 Jan 05, 2008
    the emachines modle T2893 was working just fine untile one night were I was up until 2am on the computer and went to bed (dont remember if the computer shutdown). however the next morning the thing just simply wouldn't turn on and i couldnt get it to work. I looked into the power supply and found a lose pice... so i got a new power supply, the motherboard shows a green light but the damn thing still woun't turn on... need help.
    thanks for the support.
  • whimpie Aug 24, 2008
    I have a Emachines T2893 for four years.
    Suddenlly it went dead.
    Swapping power supplies did not help.
    Only green LED on the MB is lite.
    I'm reading that capacitors on the mother board went bad.
    Would you know which capacitors need to be changed?
    I am fully capable of changing them myself.
    Thank You
  • Mojambo Dec 06, 2008
    I have the same problem. The green LED on the Motherbd is on. I checked the power supply with a PS tester and it powers up properly (fan turns on) when using the tester. I can't see anyvisual problems on the motherbd. Any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Happy Holidays
Well, it could be a lot things but here is 2 very important
1) power supply bad, time to change
2) conection in the other site is low voltage or bad.
you also check if power cord is broke or loose.
Carl
Posted on Dec 05, 2007
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Power swich blinging ,does not power on
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 04, 2009 | HP f2105 21" LCD Monitor
My Lg Monitor wont show screen (Power Button Flashing)
  • Video cable.
  • Motherboard.
May 04, 2009 | LG Flatron L1750S 17" LCD Monitor
Dell E173FP Screen blinking red, green, blue, white
  • Video cable.
  • Motherboard.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
Router problems
Make sure you have the cable plugged to the right spot. Your modem to the Internet/WAN port and your computer to port 1, the 2nd pc to port 2. Try to reset the router. There's a reset button at the back of the router. Hold it down for 30 seconds. Then do a power cycle. Unplug the power from the back of the router and also unplug the power from the modem. Wait for 30 seconds. After that, Plug the power back to the modem first, wait for all the lights to be steady then plug the power back to the router. That should do it.
Apr 01, 2009 | Buffalo Technology WHR-G54S Wireless...
HELP! My HP Scanjet5470C worked PERFECTLY - not anymore
u'r scanner have to turn on first for the computer regocnize
try another power outlet, if the scanner turned on, it means the power outlet u used now is poor...
u can check the power adapter first
Mar 12, 2009 | HP Scanjet 5470c Flatbed Scanner
Samsung crt monitor
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Jul 12, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Help needed fairly urgent
Make sure everything in side your computer is in all of the way. Push down on all of the cards and the memory to make sure nothing came loose. Make sure all of the cables are securely fastened and give it another go to see if it powers up.
Jun 19, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
E-Machines T2893 PC Desktop Logo
118 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
