Question about Car Audio & Video
Kenwood cd car player
I have a kenwood cd car radio that was installed in my car... the radio was working fine one day and then not working the next day. I have a blinking display that says "Protect" not sure what that means, but it is not doing anything.
  • 78 Answers
THIS USUALLY MEANS THERE'S A PROBLEM WITH THE INTERNAL AMPLIFIER SO FIRSTLY REMOVE THE RADIO AND CHECK THAT NONE OF THE WIRES ARE TRAPPED AND THEREFORE SHORTING THE OUTPUT. IF NONE OF THE WIRES ARE DAMAGED THEN I'M AFRAID THAT YOU WILL NEED TO REPLACE THE AMP IN THE RADIO
Posted on Dec 06, 2007
I dont get any sound radio,sirris,or cd
Is there something new that was installed or modified in your car recently, even if it's not related to electronics? (even trailer hitches, running board, etc)
Have you checked if there was a ground leak at each speakers?
Are you using an amplifier other than the one in your kenwood reciever?
May 29, 2013 | Kenwood KDC-MPV622 CD Player
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
Kenwood car am/fm cd player loads cd ok but spits it out
Try to purchase a CD disc cleaner, sometimes the "eye" gets partials of dirt on the lens. If that's the problem the cleaner will fix it in no time.
May 26, 2009 | Kenwood Car Audio & Video
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
Kenwood ddx6019
the double din kit was restricting it from opening properly, once i removed it from the kit it worked properly. i had to modify the kit for it to work properly!
May 25, 2008 | Kenwood DDX-6019 Car DVD Player
Display on a Kenwood KDC-MP532U radio
not grounded well at all ground it man form main bolt on back to car chisis bet wont happen again
Mar 14, 2008 | Kenwood KDC-MP235 CD Player
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Kdc-x879
it needs a new ribbon cable. Some car audio repair shops stock these (mine does). Part is about $20-30. Labor will depend on the shop.
Sep 20, 2007 | Kenwood eXcelon KDC-X879 CD Player
Car Audio & Video Logo
134 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
