Question about HP Color LaserJet 2600n Printer
Printer HP ColorLaserJet displays Fuser Error
Hai, I am facing this error message" 50.2 fuser error" from printer HP Color LaserJet 2600 please suggest me some remedy immediately
  • 2 more comments
  • Prakash Shah
    Prakash Shah Jan 10, 2008
    it was very helpful but i am not able to recognise the fuser in the printer assembly, how to recognise it do send me a photograph if possible, thankfully jaypoo.
  • Anonymous Mar 17, 2014
    HP LaserJet Printer P3015
  • Anonymous Mar 19, 2014
    code errors oxc4eb8482 and oxc4eb0149 appeared on display, price can not be shut off
  • Anonymous Mar 28, 2014
    need to unistall a fuser for an hp laserjet 400/401
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
  • Nav Mahmood Aug 03, 2012
    Hi Everyone i had the same problem and resolved it without replacing the fuser. i have tried what hp have suggusted the leaving it off for 25 min ect. if you remove the cable fuser controller cable and plu it back it and just try it again it resets everyting and the printers starts working again. http://95.80.99.34:3080/Hewlett-Packard/... if you do the procedure on page 75 and section 5. and try again it should work. it worked for me , its such a good printer i would hate to see it go i am sure it the same case with you. good luck Nav PC Restore uk
  • 56 Answers
Hi, The Fuser has failed and needs to be replaced. More than likely you will have to call for service on this unit!! This would be the only remedy for this error message. Hope this helps. Thanks
Posted on Dec 06, 2007
  • 4 Answers
Try to check resistant in Fuser unit See more HERE
Posted on Jan 05, 2008
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Oct 05, 2009 | HP Color LaserJet 2600n Printer
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
Jun 09, 2009 | HP LaserJet 5550 Printer
User error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
Mar 23, 2009 | HP Color LaserJet 3500 Printer
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2600n Printer Logo
1,209 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
