When i push on the peddle the needle will not move. the side hand dial that controls the needle is very stiff and will not move. i have a bernina matic electronic 801
I know what the problem is. Its a cracked gear. When you have the top open look at the big fiber gear on top. It is common for these to crack and now it is stuck. Needs a Bernina service guy to replace it. There is one more smaller fiber gear near the handwheel inside that could be cracked also.
You may have a piece of fabric jammed under the feed dog, or you may have the bobbin installed incorrectly, causing it to jam against the needle. Check for bent needle, and clean bobbin case
