Question about Philips Magnavox 15MF400T 15 in. LCD Television
15M170V will not power on
The yellow power light is on and nomally turns green when the power button is pressed. It will not power on with remote or power button on top of the set. Just all the sudden and has been working great.
    President:
  • 4,402 Answers
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. 15M170V will not power on - mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
WII DOES NOT TURN ON AT THE POWER BUTTON
remove the power cord from the wii. hold the power button in for 15 seconds.
plug the power back in. if the power light comes on check the color.
green is on, yellow is standby and red is totally off.
if there is a light press the power button and see if it turns on. if it does not then from a Wiimote, press and hold the power button on the remote. this should turn the console on. if the console does not turn on and the remote batteries are good you can try one more thing IF the light is on.
press and hold the reset button for 10 seconds on the system. disconnect power and replug. if you still cannot turn it on then your system is bricked or damaged and needs replacement.
in any case the power button is broken you can turn the console on and off from any remote
Aug 24, 2011 | Nintendo Wii Console
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
5 yellow blinlking lights. Power on/off doesn't clear the lights. Won't print. TIA...
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Can try it may work all the best of luck
Feb 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
12 flashing yellow lights
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
Printer will not respond
Canon S330 Turn off printer
Jul 22, 2008 | Canon S 330 InkJet Printer
Power & Yellow Resume Button flashing constantly & will not print
Ok please try
1. Turn off printer
Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Philips Magnavox 15MF400T 15 in. LCD Television Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
