Question about Ahead Software Nero 6.0 (60045) for PC
USB Audio Recording
I am supposed to record music from a keyboard onto my laptop. I bought a USB chord and plugged it into my laptop, but I don't know how to record music from the keyboard to the laptop. I only have NERO 6 installed.
Can u PLEASE help me with how to get it to record new music through the USB? Its quite urgent. I have to do this project and I have 5 days left to get it recorded!!!!!
Thank you!
Tasha
    Genius:
  • 1,067 Answers
Well its midi keybord u will need sum hi tech gear here mini box usb for your pc to get controller keybord in it thats if it has midi outs most better hi end models all have midi out need to go to guitar center buy usb interface for pc recording ok to put in midi devices ok now if u wanna get crazy u can us eyour headphone out to eth in mini jack into your sound card in but most sound cards dont have software to record only x fi sound blaster higher end models will creative recorder program u can use that to record what u here from aux in jack save as hi end mp3 then drag drop to nero to burn a cd ok got all that
Posted on Jan 06, 2008
I would like to record my own song without any pre-set chords, drums etc. Is this possible.
Please advise what model of keyboard you have purchased. Some do not allow recording without accompaniment. I might be able to help.
Dan
May 19, 2016 | Yamaha DGX-650-PortableGrand Digital Piano
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
Can't hear audio while playing or recording from my Numark to Audacity yet I can hear the audio when the transfer to Audacity is complete.
You will have got the audio muted in your windows recording mode. If you right click on your speaker icon it will say recording devices. Click that and you will be able to see all the devices and if they are activated.
Jun 08, 2017 | Numark ttUSB Turntable
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
Microphone gives a really boomy distorted sounds on certain chords with an acoustic guitar
Hi Nic
Thats exactly how you do it:) Some times it doesnt matter what you do, you will get strange resonances. Careful EQ is the best way to tone it down. Some guitars will present boominess on certain notes, thats just the way they are. Acoustics rely on this boominess to some degree. Good luck and happy recording. :) Happy to talk more to you about it.
regards
robotek
Oct 31, 2008 | Audio Technica Audio-Technica AT2020...
Recording on my Yamaha CP33 keyboard using USB
We're talking about audio recording. If so you must conntect your piano by using the L + R outputs with your sound card or mixer line inputs (that's how I do this). USB is ok if you want to use your piano as a master keyboard (MIDI). Another important thing is that you must have an additional application installed called sequencer ( for example Cubase Sx, Sonar...) which will let you store your digital music. I'm not talking about the proper settings of them because it could take a day or so...:)
Overall, you will have to learn a bit about the home studio, home recording techniques. There are tons of informations on web. A great thing is that you can use your CP33 as a master keyboard to control additional virtual instruments (VST) or for example play different piano samples (check Synthogy Ivory). Possibilites are endless!
Regards
Radek
May 24, 2008 | Yamaha Full-Size Keyboard
Casio CTK-720 USB computer/music connection
1.Download Audacity -
http://audacity.googlecode.com/files/audacity-win-unicode-1.3.9.exe
2.buy a cable for sound input, with 3.5" connector on both sides (like
the end of mic/phones)
3. connect cable from Phones/Output on keyboard to a PC where you
connect your stereo
4.run Realtek program for sound, go to Mixer/Record and enable Stereo Mix,
then in Audio I/O click on connected device and assign Line In.
%. Now run Audacity and start recording sound,you should hear your keyboard
May 16, 2008 | Televison & Video
M-audio 49e
Youve gone through the settings to make sure it is sending and your computer is receiving on the same midi channel?
Aug 26, 2007 | M-Audio M AUDIO RADIUM USB KEYBOARD...
Ahead Software Nero 6.0 (60045) for PC Logo
269 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
Tony
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
