Question about Speed Washing Machines
The functions on my wd80130f front loader seems to work normally however it does not go into high speed spin . It is like a motor's capacitor is not functioning as if it is not getting enough power
It's not a draining problem , on rinse/spin the motor gives a jerk and tries to spin but does not go into high speed .
    Master:
  • 254 Answers
Or the water hasn't completely drained.
See if this gives you the answer you're looking for -
https://www.youtube.com/watch?v=By1E4j9S530
Posted on Jul 11, 2019
SOURCE:
SOURCE: GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Posted on Jun 08, 2010
  • 1294 Answers
SOURCE: Front Loader not spinning all water out
Sure there is somethng clogging, first check you outlet filter; this is to be done once in ten days or so, according to your usage. Look in your manual for the details. Most machines hv the door in the front of the machine. Next is to check the hose coming down from the bottom of your tub, to the filter, to see if a sock or something is clogging the hose. Finally the pump. Plug off the wall socket first. Things shd be fine.
Posted on May 29, 2007
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 2841 Answers
SOURCE: loader than normal noise but no heat,every thing
If you are hearing a loud buzzing noise then it may be the Power Diode, Magnetron, or High Voltage Capacitor. This link will tell you how to test & replace the defective part. http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Posted on Dec 02, 2009
SOURCE: Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Posted on Dec 28, 2010
Runs fine on low speed hums on high speed (turns slowly) is it a capacitor problem, internal windings or controller?
Motor itself is the culprit.
Capacitor helps the motor to start spinning from a dead stop, so NO, it is not a capacitor problem.
Probably high speed windings. Means - New Motor needed.
Another possibility, is the controller could be sending power to "Both" sides of the windings: High speed & Low speed at the same time. But normally when this happens, you hear a loud buzz type of sound, motor will spin slowly - if at all.
Good Luck
Mar 11, 2015 | Pool & Spa
My 10+ yrs old Frigidaire gallery # GLTF1240AS front-loader drum won't agitate/spin
Check and see if the drive belt broke? On mechanical agitators using gears, a solenoid may fail and drive motor won't function.
Dec 23, 2013 | Frigidaire Washing Machines
My brand new Whirpool front loader 1073DD makes a high pitched whistle when starting to spin and spinning, is this normal?
That actually is a normal sound, The machine is spinning at such a high speed rpm that a whistling noise is a common occurence.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 14, 2012 | Whirlpool Washing Machines
Maytag neptune washer won't high speed spin
Try either capacitor or motor brushes. Your voltage isn't quite high enough or it's not getting through
May 19, 2012 | Washing Machines
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
Will only spin slow speed will not spin at high speed. Everything else seems to be working fine.
Make certain that your selected wash cycle designates a higher spin speed. If so, then you may have an issue with the motor or motor control board. Contact an appliance service company.
Feb 22, 2010 | EuroTech EWF172 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
27 people viewed this question
Top Speed Washing Machines Experts
Lollo Pop
jeff5may32
Marvin
Marvin
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
