Question about Mitsubishi HD-6000 DTV Receiver / Video Recorder
No audio from Samsung DTB-H260F
Last Christmas I recieved an Olevia 323-S111. I had it hooked uo to cable and it performed perfectly.
Today I attachedd Samsung digital HDTV receiver DTB-H260F with an HDMI cable. Beautiful picture. No sound. Switched from Dolby to PCM, attached cables from audio out to TV'ds audio in. Nothing.
Mutes on both are disconnected.
The Samsun was last one in store, display model, no owner's manual.
Help, please.
  • 2 more comments
  • sporker Dec 30, 2007
    Same issue. Onkyo SR605 receiver, with HDMI in from a DVD player (audio and visual works perfectly) and HDMI in from Samsung H260F. With the Samsung, the video is fine, but the audio is intermittent. After all kinds of machinations I can make get audio back, but I lose it again if I switch to DVD or alter the receiver's settings. The receiver and the Samsung are both new--I don't know where the problem is.
  • Anonymous Aug 08, 2008
    Same problem, no audio when connected via HDMI to a SAMSUNG HDTV. Analog hookups work fine and the TV happily plays sound from Apple TV via HDMI. Samsung not compatible with Samsung? Ha ha.
  • TejasToolMan Oct 06, 2008
    same prob here as well, I've used multiple tv's, I've tried coax, component & HDMI... makes me wonder if it's bad?
  • DL6305 Nov 07, 2008
    similar issue...just out of box tuner....great video on an hd-tv ready panasonic tau tv with a 25 year old antenna in the attic...component cables/audio cables (no hdmi port on the tv) and there is no sound...the manual's trouble-shooting guide is silly....help!....couold this be an antenna issue?
    Problem Solver:
  • 5 Answers
I have a sr605 Onkyo receiver and just hooked it up to a new Mitsubishi 73" and I could not get the picture to work, sound did though. Here is the problem the Onkyo is HDMI 1.3 but TV calls for HDMI 1.3a. There is a big difference between the 2 and the Onkyo will not work with TV. The newer model TV'S say in the manual Category 2 V 1.3a. You need to make sure that all your parts are compatable. It makes a big difference.
Posted on Feb 18, 2008
I need a code for a remote for a Samsung dtb-h260f hdtv receiver
Google the model number of the remote for a owner "manual" to obtain a list of possible codes for the set. Most universals have about 50 possible codes built into them and also have a search feature where one can try each and every code to see if one works.
May 02, 2012 | Televison & Video
Samsung DTB-H260f. Does this unit suffer from the
Yes it probably has a bad cap in the power supply. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7804
Jan 24, 2010 | Samsung DTB-H260F
I came home yesterday simply turned on the TV the
Check the power supply for bad capacitors. See this link for more information: http://www.badcaps.net/forum/showthread.php?t=7804
Jan 22, 2010 | Samsung DTB-H260F
Unit will only stay on for 20 sec. after you unplug it for about 30 sec. Blue power light can not be turned on again unless you unplug it again. Unit is not functioning with the light off, so it is not...
I just had the same problem on my samsung DTB h260 on Dec 20 2009.I am trying to search a answer.A nephew brought his WII remotes over and his Wii remotes lite up and my wii and dtb h260 shut off.Had to unplug Wii and replug it into wall. It started up but the dtb h260. Wierd like interference.
Dec 11, 2009 | Samsung DTB-H260F
I have had an outdoor antenna for several years to recieve HD local. Before the conversion I purchased a Samsun HD Tuner. It was working fine will all channels working and guide providing all program...
8 11 & 14 are std definition. All digital channels are 1.1, 1.2, 1.3, etc. You may need to re-align your antenna. Digital is Very Very direct, analog was very scattered. Hope this helps
Jul 08, 2009 | Samsung DTB-H260F
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Nov 28, 2008 | Toshiba Televison & Video
Olevia lt 27 hv no sound
one way to test the audio on the tv is to connected a cable line or ant.. and see if audio comes out on the speakers of the television.. if they don't then go on the menu under audio and make sure the speakers are not turn off..
If you get audio with the ant or cable channels.. then the television speakers are on.. now you might want to try the sat receiver with different connections an example will be AV cables.. yellow, red and white.. to see if that works ? make sure the red and white are right next to the yellow input or else you wont get audio..
If you will like more help.. you could also contact this company called Amergence Technology they have trained technicians that have knowledge for Olevia products.. there number is 866-965-3842
Mar 17, 2008 | Olevia LT42HVi 42 in. LCD Television
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Mitsubishi HD-6000 DTV Receiver / Video Recorder Logo
564 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
