Question about GPS
Hi regarding nokia n70-1
In my mobile nokia n70-1 am not able to switch on even i press power butten its not happening, battery is in charged condition.
  • boplegs dad Mar 31, 2008
    when switched on, will only display screen for about 1 second and then swirches offf again, I have only used this navman 3 times
1. You have to hold down the power button for a few seconds before it will turn on.
2. Did it suddenly stop working or has it never worked before?
3. You posted this in the GPS section. You'll have better luck getting an answer in the cellphone section.
Posted on Dec 19, 2007
Is there any code to restart my nokia n70?
first u switch off ur mobile then press 3,*, dial butten at a time on ur mobile it was farmat ur mobile then ur code change to default 12345 ok.
Dec 05, 2010 | Nokia 9300 Smartphone
Hi! I have a problem with my Nokia 7370 : the screen is blank and nothing is happening. I tried switching it off, then on again, but no luck, I have nothing but a blank screen. Even when I plug the battery...
can u hear any sound like nokia tune which comes when u turn on your mobile? It could be because your display is damaged or not working so please visit nokia showroom and they will help you.
There can be several things which can be reason for blank screen like:
1. Your display is not working
2. Battery of mobile is not working.
3. May your mobile is not charged and charger which you are using is not working. Try charging with some other charger of nokia same pin.
4. It could be software issue. Please update software in your mobile.
60% it could be a display issue.
Jul 21, 2010 | Nokia 7370 Cellular Phone
Freezes up and switches off
HI there its a problem of your mobile software. Please reinstall the nokia phone software from NOKIA website and use it. Then your problem will solve 100%. Thanks.
Mar 10, 2010 | Nokia 5310 Cellular Phone
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Hi Friend,
Initially u have remove the sim card and the battery.
Once u have removed insert only the battery and put to charge for 10 to 15 mins.
then remove the mobile from charger and insert the sim card.
Now after 30 sec switch it on.U will be able to do the process
May 29, 2009 | Nokia 3230 Cellular Phone
Nokia 6610
hi thanks for using fixya!
Is your phone is Nokia 6600? Try to turn off your phone and remove the battery and install your battery again, then turn on your phone again. Check if improves, if not, better to bring up your phone to a service center. It is usual to experience that kind of problem if you are having an old phone and not so updated to present firmwares.
If you need further assistance, let me know
Pls rate me positively! thanks!
Mar 26, 2009 | Nokia 6600
Take backups of ur phone books,calender and others, then simply enter the code
Just enter the code-
Then it asks for security code enter ur security code whose deafault value is 12345
The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
This step is known as flashing of phone. Always do this step at last (after 1st 2 steps are over and u are not successfull)
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be left)
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
then press the power on/off to swtich on the phone.
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it).
Please let me know your feed-back.
Technical Associate
Apr 03, 2008 | Nokia 6680 Handheld
6600 nokia
try to reformat ur fone by hard format
Sep 24, 2007 | Nokia 6600
Nokia 6600 does not open
aapko apne cellular phone ka software update karna hoga
Sep 18, 2007 | Nokia 6600
GPS Logo
128 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
