Question about Motorola Mobility V262
Cell phone wont charge
The charger port wont grab and engage the charger. battery is fine, charger is new. phone displays fine but 'low battery' warning comes on .loose port?
  • Anonymous May 28, 2008
    the chargeing port dont work
  • 38 Answers
Yes, it sounds like a loose charging port contacts/connectors.
Posted on Jan 08, 2008
When ever i try to charge my phone it wont charge. I brought a new charger and new battery still wont charge
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Adieh
Sep 12, 2011 | Sanyo Incognito 6760
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
My LG-VX9200 wont turn on and the battery wont charge. I assume is the battery, its a practically new phone. It hasnt get wet either. What can it be? Thanks in advance
Before you conclude that the battery is the problem, i suggest, you get a similar charger to charge your phone first, if the similar charger charges the phone, then, ii means you are having charger problem, but if it does not charge the phone, you should be considering the idea of getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad, you can use your charger to charge a similar phone and see if it charges, if it does, then, the problem is either th battery or the charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
Jul 18, 2010 | LG enV3 VX9200 Cell Phone
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Motorola Mobility V262 Logo
190 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
