Question about GE Profile Harmony DPGT750EC Electric Dryer
GE DRYER STOP RUNNING
GE Dryer was running then there was a loud noise and it stop running.
Cannot turn drum by hand.
Bolivar.........HELP
  • Anonymous Mar 16, 2014
    the drum will not turn it is getting hot but not turning
    Problem Solver:
  • 9 Answers
Sounds as if the belt has snaped and the drum has droped stopping you moving the drum
Posted on Dec 06, 2007
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
I get a loud scraping noise when I first start up the dryer
It sounds like the drum is off balance, the drum could be scrapping along the side of the dryer. Check for a loose bolt on the drum assembly. Once it starts running the drum levels out and the scrapping noise goes away
May 14, 2011 | GE DVL223GB Gas Dryer
Drum turns when dryers not running
Does the drum just constantly turn and never stops or does it just take a really long time to stop? If it just takes a long time to stop it sounds like a loose belt. If it just turns and turns and turns something in the control panel isn't telling the motor shut off but with the clunking sound you're hearing I'd guess its the belt.
Nov 04, 2009 | Frigidaire GLER341A Electric Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
My Stackable washer/dryer is not operating right
Two things:
1) I would first check your water pump, if something gets in it or the water pump bearing is bad, it makes this kind of a sound.
2) If you can spin the washer drum by hand in either direction, the transmission is bad.
Good Luck!
May 03, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
GE Profile Harmony DPGT750EC Electric Dryer Logo
198 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
