Question about GE JKP15 Electric Single Oven
Stove I bought a new stove but there was know cord hooked up to it, how do i hook up a new cord.
  • 833 Answers
Go to page 8 here:
Essentially, you need a 220 volt hookup kit from any hardware store. Match the plug to your outlet. Several styles are out there. There are three wires in the cable. Knock out one of the holes in the box on the oven. Install a strain relief for the cord into the hole and clamp on the cord. Generally, they're in the kit. The Red and Black wires are 'hot' and white is neutral. The connections are labeled on the stove. Make sure your connections are neat and tight.
Posted on Dec 07, 2007
No stove wires hooked up to neutral
The older electric hookups for ranges used only the 2 hot wires and a ground. Somewhere on the range the neutral and the ground should be connected together. This connection is no longer accepted by the National Electrical Code, but no one is going to force you to change the wiring unless you change the range.
Where is the ground wire attached? Some ranges had a metal jumper to connect the neutral to the ground. Your oven element is 240 volt only. It does not need a neutral. The ground/neutral wire is for some of the controls and the clock.
Aug 13, 2015 | Kenmore Stove / Oven / Range Bake Element...
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 | Ovens
Yes I just bought a new stove today and the electronic display is not working. It is a frigidaire lgef3045kf
I an assuming that the unit was hooked up correctly, because if you missed a wire or a wire slipped out the the wire nut, this could happen. I would suggest to 1 double check the breaker and make sure it was turned on. If it was, then you will have to recheck the installation of the wiring to the oven. Yes it is possible to get a DOA unit, but is very rare. I hope this helps.
Jul 13, 2011 | Ovens
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
Stove top works. no gas to oven
you may have a bad ignitor if unit doesnt have a standing pilot.....there may be a lever that needs flipped on the regulator. the regulator valve is where the gas line hooks to on the stove
Mar 06, 2010 | Ovens
The door on my Okeefe and Merritt antique stove will not close snugly against the frame. There is a slight gap at the top of the door. I have been told that the spring inside the stove needs to be...
O'Keefe and Merritt is always a challenge to the inexperienced because, although two stoves of the same year and model can look identical, there are subtle differences in both, especially in the door spring mechanism, that make it difficult to explain without seeing the stove and/or asking you a series of questions in person. Here it goes anyway: Some models have access panels that are visible when you pull out the broiler drawer. This makes changing a spring a breeze, as long as you know which spring you need. A sample of a broken one, or and intact one always helps when buying a replacement. Other models operate on a system of hooks, cables and springs. These often require a skilled technician to come out and repar for you. Most of the time, the door has to be physically removed from the frame so that new cables (and sometimes rods) can be installed on the hinge and then the door would have to be re-installed fishing the cables through a small opening on the bottom of the stove. A spring then attaches to the cable and the hook of the spring is then attached to one of three small aligned holes on the bottom stove panel.
One constant i s that there are 2 sets of springs for each of the door panels. You are right, there are springs in the middle. And you are also right that the white panel removes from the door after you remove the truss head sheet metal screws.
You might want to give me a call and chat about this further at RMR Company, Inc (RMR Stove Company) 619-231-2808
Dec 04, 2009 | Stoves Ovens
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Electric stove
Could you be more specific? You mean (I assume) you bought a stove and can't connect it to the wall?  That would be because they don't come with a cord.  You buy it separately... I work in a Home depot.. we carry them.
Mar 08, 2008 | Ovens
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
GE JKP15 Electric Single Oven Logo
142 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
