Question about Magic Chef Washing Machines
A magic chef 1.6cu ft portable washer.i heard a buzz, from the area above the drain hose. right before shutting off after the spin mode,sounds like a straining pump or loose washer.
SOURCE:
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
  • 213 Answers
SOURCE: washer wont spin
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Posted on Nov 22, 2007
IFIXALL
  • 869 Answers
SOURCE: Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
Posted on Jun 07, 2008
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
  • 129 Answers
SOURCE: MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Posted on Feb 02, 2010
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
Jan 19, 2017 | Magic Chef Washing Machines
Yes, where & what is the internal rubber ring on a Magic Chef 2.1 cubic ft. Portable Washer?
Go www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a video that shows disassembly.
Aug 02, 2016 | Magic Chef Washing Machines
What is the error code E2 for Magic Chef 2.1 cu. ft. Top Load Portable Washer?
I put this answer in the comments but re-posting here because I didn't know what I was doing : )
The Magic Chef 2.1 cu ft Portable washer manual says that its a door malfunction and the solution is to open and close the door. That did not work for me so if you're having the same issue that I am it may be that your washer is not level. I had placed mine on top of a few folded throw rugs to stifle noise (I live in an apt, on the second floor) and the rugs were uneven. As soon as i adjusted them, the washer began to work again. I hope this helps.
May 26, 2014 | Magic Chef Washing Machines
W225LV water flows and drains constantly. Tub won't fill up
HI, this is a siphoning issue.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Sep 20, 2009 | Magic Chef CAV2000 Top Load Washer
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Apr 07, 2008 | Washing Machines
Itis a 'no spin".
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Washing Machines Logo
Top Magic Chef Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
