Question about Fisher Paykel EcoSmart GWL15
Washing machine water filling very slowly
  • Isobel Speer May 11, 2010
    I have the same problem. Flow is good from the wall and new hoses installed. Are the screens easy to clean and then be put back again? Do they just pop out.?? Are their 2 screens? One on the hot and second for the cold water entry?
    President:
  • 1,294 Answers
You have to check whether the water flow is good from your tap in the wall. Then check for blocks in the hoses; there are screens also in the machine (at water entry) which should be cleaned up.
Rate me pl.
Posted on Dec 05, 2007
I have a toshiba washing machine model :aw-sd130sb: error code ec5. But this time solve the problem?
Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
Jan 09, 2018 | Washing Machines
My Kenmore HD plus 80 series fills up tub slowly, starts cycle before its full.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 13, 2011 | Dryers
Cold water comes out very slowly whereas hot or warm is normal
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Sep 27, 2010 | Kenmore 12502 Top Load Washer
MAchine fills slowly. Have cleaned the screens.
Check the solenoid. You can swap the hot and cold water hoses and set the wash for hot but cold will come out. Then you can see if the flow is better. If it is the cold valve isn't opening all the way.
Mar 11, 2010 | Washing Machines
The washing machine doesn't fill with water - it
WATER LEVEL SWITCH MIGHT BE BAD. SOME MODEL HAVE A FLOW METER. DISCONNECT THE WATER HOSE AT THE WATER VALVE AND SEE IF ANY DEBRIS IN THERE
Jan 24, 2010 | Kenmore Washing Machines
Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Aug 12, 2009 | Washing Machines
Slow water delivery into machine
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Q - My washer fills slowly with water, what can I do ?
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Mar 14, 2009 | Fisher Washing Machines
Water very slowly fills Whirlpool washer
Check the screens inside the water valve. They get plugged sometimes. Also check both ends of your hoses. When installed most companies put screens or screen (1) in the cold water line at the valve.
Nov 18, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Fisher Paykel EcoSmart GWL15 Logo
93 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
