Question about Sony KP-53V90 53" Rear Projection Television
AUX to normal channels!
I cannot get my TV to get from the AUX to the regular TV settings. It goes from AUX 2 - 6 but then transfers to Video 1 - 4. I have the cable hooked up from the wall to the TV to get 02 - 99 channels but it still doesn't work! help!!!
    President:
  • 4,402 Answers
Have you done a hard reset? (Unplug the tv for a couple of hours, then power it up again).
Posted on Dec 05, 2007
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Front Audio Video inputs not working
What model TV is it?
it may be you need to change the input to video 1 or video 2 to get those front jacks to work. if there is a TV/Video button on the front you should be set. If not you may need the remote control. Sometimes changing the channel to below channel 1 will give you that option.
Nov 20, 2008 | Televison & Video
Setting up TV
There probably is a TV/Video button on the bottom of your TV. Push the button until the screen changes to a regular screen. The TV/Video button is also on the remote most likely. Just keep pushing it. Often there are 2 or 3 aux channels. Hope it works!
Aug 11, 2008 | Sylvania Televison & Video
Recording Sony Handycam video footage to video
You have to tell the vcr which input to record on. Instead of a channel try "Line 1" or "input 1" or "Video 1". you can get there by going to channel 01 and pressing channel down a few times. match whats written above the input jacks with what's on the screen.
Aug 03, 2008 | Televison & Video
Programming AUX as a channel.
pick up a universal remote
Mar 28, 2008 | Televison & Video
Tv will not receive any signal from remote
you should be able to scroll down on the tv 's channel buttons to get to the s-video, video 1 ect. inputs. there may also be a video/aux/source button on the tv you can press.
wg
Feb 11, 2008 | RCA P61927 61" Rear Projection Television
AUX mode
Try to disconnect power for at least one day.
good luck---------tomtaso
Nov 04, 2007 | Zenith B32A24Z 32" TV
Sony KP-53V90 53" Rear Projection Television Logo
116 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
