Question about Akai PT4799HD Rear Projection Television
PT5299HD screen I need to find a new screen for AKAI HD rear projection television.
  • 4 more comments
  • bgwessam101 Jan 11, 2009
    where can i get s replacement screen?
  • Anonymous Feb 01, 2009
    I need a replacement screen also but have been unable to find one. Anyone know where we can order one? Or anyone have a nonworking Aika pt5299hd that would sell me their screen?
    I also need a new screen for my aika PT5299HD. Someone accidentally ran into it and the left hand corner is broken. Does anyone know where we can order a new screen? Or have a broken one they would sell for parts?
    I also need a replacement screen for my aika PT5299HD. Where can I get a new or used one from??
  • sbnnka Mar 12, 2009
    I have a pt5299hd akai tv for sale. only three years old. sbnnka@sbcglobal.net
  • Deuce 22 Apr 28, 2009
    I have a 3" crack on the screen of my 52" (pt5299hd) set I need a new screen can anyone HELP!!!!!!!
I had the same problem trying to find a new screen. What I did was found a local plastics shop and had a piece of 1/8" plexy glass that has one side anti-glare. It was only $50, and its alot more durable.I had a few problems changing it though. First you have to pull the rear bottom panel lose, then the rear top. Once the screen is exposed (TAKE THIS ADVICE), put a small piece of tape on one of the top corners and mark its position. This has a two part screen and the inner one is a image magnifier and goes only one way. It took me 4 trys to reposition it right for a correct picture. Once you do this carefully unbolt the two side and top screen brackets. Make sure you dont mess with the four centering sensers. Only loosen the screws on the bottom screen bracket. Take the screen out and seperate the two screens by removing the tape around the edges. You will now discover that only the outer antiglare screen is craked. Clean the three inner sides with windex and a paper towel, then use a cotton rag or tee shirt to eliminate any particles left behind. Once you get the screen in place dont over tighten the screws they strip very easy. Since you have the tv apart you should go ahead and blow all the componits off with a keyboard cleaner, and clean the bulbs with a super soft cotton teeshirt with a small spray of the windex on it, dont spray the bulbs directly, and do the same with the mirror. Remeber that all streaks will show up on the image screen. Clean the out side of the screen after you put it back together. Oh yeah, make sure its unpluged first.
Posted on May 24, 2009
I have a pt5299hd akai tv for sale, only two years old but needs a power supply unit. I will sell it for 200.00 or best offer.
Posted on Mar 12, 2009
I need a aligment and adjustment .
Posted on Apr 19, 2008
Akai PT4799HD "Mode not supported"
If its HD the set is only HD ready which means it does need a compatable box.
Dec 04, 2012 | Akai PT4799HD Rear Projection Television
Are projection TV screens interchangeable? Can I replace my broken AKAI screen with a good Hitachi screen if they are the same size and both HD? I have an AKAI PT5299HD tv and am in need of a...
Yes, if screen or rear projection tv is same size then it can be used in other tv, basically it consist of 2 or 3 layers of screens and almost similar so can be used in other model.
Thanks.
Nov 22, 2010 | Televison & Video
HOW DO I RESET CONVERGENCE ON A AKIA PT5299HD
it will show you in your owners manual or in the menu portion on your TV. Remember you only have about 15% ability to do this and the tech has the rest in his ability to adjust.
Sep 21, 2010 | Akai PT5598HD 55" Rear Projection...
We have a akai 52 in television model #PT5299HD and we are getting double image-also i trying to find a free manual on the television-it is it just turn 5 years old and has hardly been used as husband had...
You need to replace the convergence ICs 2 of them they will have PN on them,example STK392-110 Big Black ICs
Mats Electronics has them 1-800-628-1118
Sep 21, 2010 | Akai Televison & Video
Where can i get a replacement screen protector for my akai tv 47 inch rear projection
Not replace able,beacuse the DLP screen cost the same as a new not including labors.Tv not worth it to just replaced the screen.
Jan 12, 2010 | Akai PT4799HD Rear Projection Television
Cracked tv screen
I have the same TV and the screen is like new
I am moving to a smaller apartment so I can sell it to you for $ 400
Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
Need link and part number for STK-IC for AKAI PT4298 HD rear project convergence fix
The ICs you need are STK392-040 you will need two of them. You cant get the ICs or Radio Shack as they are specialty items. You can get them at the following link and they will provider free instalation instructions as well as free tech support just in case you need extra help. heres the link.
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Akai PT4298HD Rear Projection Television
CONVERGENCE
Solution for your tv problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
One last check and a quick dusting of the lenses and mirrors, then I powered it up for a "smoke test". It worked! I screwed the back on and reconnected all of my video sources and moved it back in place. I only had to do a minor on screen convergence adjustment and then it looked perfect again.
It took me about an hour and a half. The parts cost $5.99 each, expedited shipping was around $16. New soldering iron and bulb cost me about $25 and the heat sink compound was $5. So the repair cost me less than $60 (and would have been less without tools). Compared to a repair estimate of $500, I saved over $440!
Jan 13, 2008 | Akai PT5598HD 55" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Actually...it's a Akai PT5299HD
I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
Jul 31, 2006 | Akai PT5598HD 55" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
437 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
