Question about Motorola Mobility H700 Wireless Headset
H700 no change
Straight out of the box the H700 turns green when plugged into the charger. It should turn red when charging. Green is supposed to mean that it is charged so I tried to use the call button to get the purple indication and there is no light at all. I tried to leave it on the charger for awhile and it made no difference.
  • 2 more comments
  • coryleblanc Dec 06, 2007
    Same problem here, just opened the box, charged it for about an hour and the light was green. When i unplug it and open it, the light should turn purple, but mine doesn't.
  • archerladie Dec 21, 2007
    Bought mine off Ebay. Plugged it in to charge and light was already green. Never seen red, purple or any other colour. Take it off the charger and no lights,nothing, can't power the device on either.
  • jeremy74 Feb 05, 2009
    I have several units I am trying to sell on ebay and I'm finding everyone I'm selling has this same problem. Please help
  • siar7 Apr 06, 2009
    Same problem here. Green light when plugging to charger. Absolutely no way to turn on. New unit that came with a krzr motorolla phone and has been sitting in a box for a couple of years brand new. Seems to be quite common... Checked on Motorola's website and the unit is 100% original. I plan to stay away from Motorola Bluetooth headsets.
Sounds as if you all have defective units
Posted on Jan 15, 2008
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
My h700 won't turn on
Mark-
I remember this headset being difficult for people to get in pairing mode. You can find instructions here. H700 Different Paring Instructions
Mark
Motorola Support
Apr 25, 2014 | Motorola Mobility H700 Wireless Headset
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
May 19, 2010 | Motorola Mobility H700 Wireless Headset
WHy is air hog battery charger flashing red
I had a Storm Launcher battery that was unused for sometime and when I plugged it in to the charger, the light flashed red. I checked the voltage of the pack and it was down around 2.5V....from 7.4V. I figured the "smart charger" thought it had a dead or shorted cell and wouldn't kick in the charging circuit. I McGyver'd the two probes and alligator clips to connect the pack to a 9V. NiCad "dumb" charger. The light came on showing a charge and I left it for 5 mins. Unhooked it and checked the voltage. It was now 5 volts...supposed to be 7.4...but much better than 2.5. Plugged the pack into the AirHogs charger and the green light started flashing, indicating a charge. Later I got the double-flashing and 10 minutes after that FULL charge! Just needed a boost to start the smart charger.
Apr 03, 2010 | Air Hogs Radio Controlled Storm Launcher...
It wont turn on
With the boom closed, insert a plugged in charger and make sure the unit is fully charged. The light will turn from amber to GREEN when it is fully charged. Unplug the charger and open the boom. It is now "on".
Aug 23, 2009 | Motorola Mobility H700 Wireless Headset
H700 wont do anything
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
Feb 09, 2009 | Motorola Mobility H700 Wireless Headset
What tells when fully charged?
On the Motorola H700, the light will turn from red to green.
link to your online manual
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Good Luck
Jul 14, 2008 | Motorola Mobility H700 Wireless Headset
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
1,067 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
